Hey guys, my 2013 has about 70K miles and for about the last month or 2 has been sluggish to start up.
What I mean when I say that is, on the final crank when the engine would normally fire quickly it seems like it struggles to fire and hesitates for a second but it does always start. Once it is running it is perfect and it only happens after it has sat for a while (ex: over night).
It is not the battery as it does not struggle to crank the engine and no dimming lights etc.
Its not the spark plugs because I just changed them 3 weeks ago and it was having this "problem" with both old and new plugs.
It probably isn't injectors or fuel filter because it runs perfect after it is running or if it hasn't sat for to long.
I can only imagine that the fuel is leaving the engine after it sits for to long.
One thing that i did change around the time this started happening is i began using Shell gas only. But i don't think that would be the problem.
any ideas? and if so, is this something I should address or is it not going to hurt anything?
thanks,
Christian
thanks,
Christian
