I have a 2005 ram 1500 4wd automatic with the 5.7 Hemi that sometimes will start others the starter will just click. I can get it to start by grounding it out from the battery when it decides not to start. I have replaced all of my ground and hot wires with with 2ga wire, I run a new optima yellow top, new alternator, and new starter. In the mornings it'll start just fine but when I get to work (30min drive) if I shut it off and try to re-start it it'll just click and it won't show what gear I'm in (has the little box around all gears) even after I get it started. Everything else looks/functions as it should. Could it be the trans range selector? But range selector was replaced about 5k ago could it have gone bad that fast?
