I have a 2014 Ram 1500 with Uconnect 8.4 system.
I'm experiencing significant lag times (sometimes up to 30 seconds) when I switch my audio source to USB or SD. It will also confuse the USB and SD sources if I touch the on-screen buttons while it is switching sources between the two.
I'm also experiencing lag with the climate control system, which is controlled through the stereo unit. It can take 5-10 seconds for the heater/ac fan to begin blowing after I turn it on.
Is this a common issue with Uconnect, and if so, can it be fixed? I've had the issue since the truck was new (6 months ago), and had the dealer flash the latest update onto it a while back, but it didn't seem to help. Everything does ultimately work, so it's not really a critical issue, but it is annoying.
