1 - 2 of 2 Posts
2000 Dodge Ram 1500 radio won't work. Mechanic changed battery and now radio doesn't work. Think I found the radio code but don't know how to program it. Any ideas?
is anything else not working? also check your fuses, the one for the radio (i belive 8) and your IOD (13) my radio wasnt working today after doing some work to my lights my dome light broke, cargo light, and other few other lights. after pulling every fuse (except the ones with those clips) i pulled the one in 13 (I.O.D.) turned out that was it. pull it out as far as you can, and with a small screw driver go to each clip and ply the case on the side of the fuse, it will come out, check that one, otherwise im not sure what the code is, but food for thought
1 - 2 of 2 Posts
