1 - 3 of 3 Posts
Discussion Starter #1
I towed my trailer with quads recently and it was only 10 celcius outside, my temp hit 100 degrees fairly easy. I'm wondering my options on additional cooling or upgraded tranny coolers. Has anyone does this or have recommendations because I'm assuming when its 30 degrees this summer my temp will be way to high when I'm towing with my 2014 ram 1500 sport.
See if MagHytec makes a trans pan for your Ram. Also a differential cover.:smileup: In fact, you may be able to use the giant pan from a 68RE transmission. Check with the folks at MagHytec. Welcome to the forumz!
Premium Member
you might check to see if the tranny cooler out of a 2500 or 3500 Ram has a larger capacity
They should all have the same height & width, the thickness may be different
1 - 3 of 3 Posts
