1 - 3 of 3 Posts
I have a crazy idea and just curious if a guy could fire and time the ignition coils of a v10 magnum by a stand alone ICM and eliminate use of going the the stock pcm and such
The pcm changes the timing also and for what purpose would you want to run a separate control module that will do the same thing as the pcm?
Discussion Starter · #3 ·
Actually to make a draw through carbureted supercharged system, want to eliminate injectors and because the v10 times off of crank and cam sensors was wondering if there was like an MSD ignition system that you could adjust timing of and run both packs
1 - 3 of 3 Posts
