1 - 10 of 10 Posts
Has anybody done the V6 electric fan conversion for their 5.7 hemi. i’ve seen a few videos and it looks like it would be a great fuel and power saving option. I’m in Arizona just want to make sure that the fan would keep the motor cool enough. If anybody’s done this and had good or bad results please post them here I’m thinking of doing this soon .
It cleans up the engine bay, that's it.
No measurable mpg gain.
Minimal power gain in the higher rpms - not much to really speak of at normal driving rpms. Maybe a bit in city traffic as your clutch fan might actually engage then.
From what I have read, you will need a programmer to adjust when the fan kicks on and off. I also see a lot of people upgrading to 180 tstat as well to keep the temps down.
No you don't, it's a PWM fan to begin with and has no issues idling with AC on max in Florida sun. It works perfectly.
From what I understand all 2019+ Hemis have a electric fan only... so looks like what the owner community figured out years ago (swapping the bigger V6 E-fan into the 5.7 Hemi and deleting the clutch fan) has possibly changed the way Ram designs their newer trucks.
Update:
I did it this weekend. Pulled out the clutch fan because the clutch was failing (sounded like an airplane when going over 30 mph) and the AC condenser was not keeping cool enough. When I pulled the clutch fan and the monster cowling off, the stock E-fan looked way underpowered and there was nothing to force the air to channel through the radiator and condenser. So I ordered the V6 stock E-fan, which is considerably bigger and has an integrated cowling. Installed easy (if you order, make sure the plug connection matches) and it works like a charm. The engine temp stays just under halfway (hottest day here was about 90, so we'll see how it does in the summer) and the AC blows cold even at idle. Cost me about $160 and about 2 hours of my time. Well worth it. Can't speak for gas mileage or power, and I could care less about those, just needed the engine to stay cool and the AC to work.
Update:
Did you order the E-fan from dealership? If you can DM where you got it from I am wanting to do this as well.
I got it from RockAuto.com they have a selection of multiple brands and each will have a picture of the part as well as a picture of the connection so it is easy to make sure you are ordering the right one. The hardest part is removing the stock pulley fan, you'll need an air hammer, and remember it is reverse threaded.
Keep your OEM fan, the aftermarket fans seems to fail quite often and you don't want to be stranded and overheating.
It might be possible to replace the aftermarket motor with the OEM fan motor, I haven't looked or tried since all I have are OEM.
1 - 10 of 10 Posts
