1 - 20 of 24 Posts
Want to install the in channel vent visors on my truck with automatic windows? Has anyone been able to do this yet? I have found out anytime you have an obstruction or anything in the channel at the top of the door the window will automatically go down. The way they look on the truck will be 100% nicer. Can this problem be fixed or not?
the set I bought I had the same problem they were about a 1/2 inch to long to I cut a 1/2 inch off and they fit with no problems
Discussion Starter · #3 · (Edited)
So you had the ones that went in the channel? Where were they to long at? What part did you have to cut? Last no problem with the automatic window closing after that?
I bought the avs in channel ones. Right at the end by the mirror you have to tuck it in behind it a bit, but no problems with the windows so far.
Discussion Starter · #5 ·
So you have the automatic windows?
Discussion Starter · #7 ·
I would like to see the pics.
I put AVS Seamless ventvisors (in channel) no problems at all ... and I like the stealth look!
I have a new set of AVA sitting in the garage that I am waiting for a ggod day to do the instal. I am confised about the pc of Scotchbrite pad and where to buff. Anyone have some advice??
Buff the edge just inside the channel .... you don't have to put much elbow grease in it ... just scuff the channel a bit to help with the tape adhesion.
Can you post a couple of pics? I have the same truck and I'm about to pull the trigger on a set of these. Thanks in advance.
Discussion Starter · #13 ·
Thanks so much for all the information. It has been a really big help.
I'd be happy to sharre a photo I just don't know how to make that work on here .... I can email you some
This is from the FAQ, give this a try.
BEGIN COPY*******
How do I attach a file to a post?
To attach a file to your post, you need to be using the main 'New Post' or 'New Thread' page and not 'Quick Reply'. To use the main 'New Post' page, click the 'Post Reply' button in the relevant thread.
On this page, below the message box, you will find a button labelled 'Manage Attachments'. Clicking this button will open a new window for uploading attachments. You can upload an attachment either from your computer or from another URL by using the appropriate box on this page. Alternatively you can click the Attachment Icon to open this page.
To upload a file from your computer, click the 'Browse' button and locate the file. To upload a file from another URL, enter the full URL for the file in the second box on this page. Once you have completed one of the boxes, click 'Upload'.
Once the upload is completed the file name will appear below the input boxes in this window. You can then close the window to return to the new post screen.
What files types can I use? How large can attachments be?
In the attachment window you will find a list of the allowed file types and their maximum sizes. Files that are larger than these sizes will be rejected. There may also be an overall quota limit to the number of attachments you can post to the board.
How do I add an image to a post?
If you have uploaded an image as an attachment, you can click the arrow next to the 'Attachment Icon' and select it from the list. This will be inserted into your post and can be located where you want it displayed.
To include an image that is not uploaded as an attachment and is located on another website, you can do so by copying the full URL to the image, (not the page on which the image is located), and either pressing the 'Insert Image' icon or by typing
after it, ensuring that you do not have any spaces before or after the URL of the image. You can insert pictures from your albums (?) in this way too.
*****COPY END
Here ya go gents. I had these painted before I installed them. They are in-channel and I have had no problems with my windows on my Laramie.
Discussion Starter · #17 ·
Well i wish i could find a way to fix my problem. But don't know anything else to do.
i got the weather tech ones , with perfect out of the box
yes have auto windows , just had to be careful with the install
Discussion Starter · #19 ·
How much did they cost? What model do you have?
1 - 20 of 24 Posts
