A while ago I noticed moisture in the storage compartment underneath the driver side rear passenger seat of my 2011 quad cab 1500,. At first I thought it was possibly seeping in from where the Rocker Panel is rusting out on the right side of the truck, but if that was the case, then there should of been moisture on the right read side as well. Since most of the carpet was wet, I pulled out a big chunk to try and determine where it came from.
The weather had been warm and the truck was completely dried out prior to a huge rainstorm several weeks ago, and after the storm I decided to check the compartment prior to driving. There was a fair amount of water the compartment, the carpet on the back of the cab wall under the seat was damp, and the carpet around the sill was wet, so I began looking above the cab for potential water leaks. The track for the rear sliding window was dry and tThe seal around the window looks good, and the carpet on the cab behind the rear seat back was also dry. There's no rust to speak of above the cab, but I noticed that the Trim molding on top of the cab is loose. I suspect this might be where the leak is.
Any thoughts? If it is the trim, are there any special tools I'll need to replace it, something like a glaziers vinyl roller?
Thanks,
David
Thanks,
David
