1 - 4 of 4 Posts
Not really. But i usually put a little silicone on them.
If you haven't done one the fan is reverse thread. Put a piece of cardboard to protect the radiator and then spin the fan off.
Thats a very good question! The FSM doesn't mention it. But I have always put some "pipe-sealant"/ teflon-paste, on the longer ones that go into the block and a water-jacket.
But mine has FOUR LONG BOLTS! All 4 need sealer?
2. Also, mine had an o-ring in the bag. I assume it is to seal one of those bolts?
My water pump has a beveled area, at the top right bolt hole - with a LONG bolt, on the W/P gasket surface the LOOKS like where it should go?
1 - 4 of 4 Posts
