7481 - 7500 of 7539 Posts
Pulled the factory rubber steering wheel and moved everything to the new leather wheel. It's ready to install, but now our heat index is at 100F! I'll finish up tomorrow morning. Right now is recliner and A/C time!
14 Ram Express
You doing a heated one w the radio controls on the back?
Sent from my SM-G988U1 using Tapatalk
Premium Member
2013 RAM Laramie Crew Cab
Looks great Omac! I'm surprised 5th gen tail lights will physically fit on a 4th gen.
I saw a 2014 RAM with them and took pictures. After researching found the 2500 bed on the 5th gen is the same as our 4th gen. The tail lights are getting hard to get from the dealer because people are finding out they fit and are buying them up.
  • Like
Reactions: MOFOGO
Time to put a snorkel on the beast!
  • Like
Reactions: Mb7640
Thursday afternoon I drilled and pounded out the studs for the exhaust flex joint on my 15 Ecodiesel. The stud is 3/8 but the fastening bolt size is 5/16. The stud is press fit in place and the capture bolt is prone to rust and breaking off. Once I got them all done I replaced with solid 3/8 stock. If the wrong one breaks while running it can melt the def injector wire harness and result in an exhorbitant cost.
14 Ram Express
Got hit in the rear tailgate and bumper awhile ago... after replacing the bumper, I tried pulling the dent in the tailgate, wasn't happening.
So today I spray painted this nasty metal mark on the center bottom side of the tailgate just to make it alittle less obvious...
Bummer about getting hit but that is a cool looking bumper Mike.
14 Ram Express
Thanks man... the corner steps really work out great! Ram should've followed along w GM w that feature...
...and follow Toyota w the Tundra's roll down rear window.
2015 Ram 1500 Laramie quad cab
I installed my Putco Blade led tailgate light. I used to be a cut and splice and kind of guy but I found a plug and play harness and used that.
Sent from my SM-N970U using Tapatalk
2021 ram 1500 warlock,5.7l ,4x4
Where did you get that from looks nice
14 Ram Express
They finally came up w a harness where u don't have to splice into the reverse light wire?! What a time to be alive!!
New tires. 35x12.5x20 TerraGrappler G2s on stock rims. 2" level kit only...on a 2wd. I also tightened up the screw at the bottom back of the front fenderwell that's poking out a smidge.
138960
138961
