1 - 11 of 11 Posts
I have a 2014 Sport with "premium" reverse lights. They are T20 base bulbs. Not 921 like regular ones. I can't seem to find anyone that sells a LED bulb that will fit these. I want error free too. Anyone have any that work?
7440 is the common equivalent of T20.
I paid extra for CAN-bus bulbs. Still gives me a bulb out warning. Really, the only sure way to not have bulb out warnings, is to actually put your own resistor in the circuit.
Buy canbus led bulbs from superledbrights and no error messages!
I went to super bright LEDs and found 11 results for a 7440 bulb. None of them were labeled as canbus.
Would you mind sharing the LED bulb number you are using?
I`m not sure of this, but i dont think the reverse lights are tied into the warning system. So, you might not need to worry about any kind of special bulb. I guess one way you can find out if they are connected to a warning system or not, just pull a reverse light bulb out to see if it activates the warning light in the dash.
There is definitely a warning for back-up lights.
I could live with a brighter bulb and not worry about the light out warning. Your only in reverse for a little bit.:doh::LOL:
All it does is chime once and briefly show a warning shortly after starting the truck.
I don't notice it anymore. But knowing that it's there does bother me a bit. I am the kind of person that can't stand having any kind of warning light on my dash.
Mine came from retro solutions and work perfect on my 2013----they light up the night...:)
921-CREE-SIDE-2X T15 CREE Reverse (Side Emitter) *****
5 Watt on the T15? Are these Canbus bulbs or not? Are you getting an error message?
1 - 11 of 11 Posts
