1 - 3 of 3 Posts
I want to lift my 2010 quad cab 4" and I need to put the bilstien 5100s in the front because my truck had such a rake when I put the 2 1/2 level kit in front it became just level I had to remove the 1.5 in the rear .... So what 4" kit would you guys recomend? and I seen in the mopar catalog that you can fit 37x12.5s is that right? I know the mopar kit is a superlift kit so if that the kit to use I wont be giving dodge the extra cash just to say I got a mopar kit......
Thanks
Ill vote RCX, but if you use the Bilstiens with it you will need to reinstall your rear spacer.
If you're going 4" and want to use Bilstiens I would just got 6". Depending on which brand of lift you buy, the strut spacer ranges from 3.5-5.5".......
1 - 3 of 3 Posts
