1 - 10 of 10 Posts
Discussion Starter #1
Hi...just taking a poll to see what type lift jack everyone is using. I've got a bottle but am thinking of investing in a floor jack for my 1993 Dodge Ram W250 Cummins 4x4.
Thoughts?
TY
NY
Premium Member
Premium Member
I would not buy a jack from Harbor Freight, i would not trust it
2 nights ago i was at the local Tractor Supply Store, they had several floor jacks in stock
I saw one brand that i would not buy, because i never heard of it.
They had several sizes of the Torin brand Big Red
https://www.tractorsupply.com/tsc/catalog/jacks-stands-ramps
They all are made overseas anyway including Torin Big Red. I had mine for 20+ years and the only thing i did was replace the casters on it.
Jack I stole from my Dads Body Shop or his Car Dealership, can;t remember which, about 35+ years ago. Biggest one he had. Thing is still a Beast.
Took it in, to get worked on, just because, but the tech at the hydraulic place took one look at it and said it will outlive all of us.
Premium Member
I have one floor jack that i lent out, it came back inop, i still want to get it repaired, it has a steel lifting pad on it that must be twice as large as the modern lifting pads
There used to be a guy here in town that only worked with hydraulics, his shop used to be seemingly cluttered with every kind of jack.
He would not work on anything made in China/Taiwan, because the O rings were almost impossible to replace, size wise & quality of the rubber.
I talked to a guy at Discount Tire & they have a guy that repairs all of theirs, i need to find out who it is
I have a 3 ton floor jack that I have put on blocks so it will lift my truck. It’s been too short since I put taller tires on it. Mines just leveled, not lifted. What do people use for their taller trucks?
Premium Member
If i am going to be working on any vehicle that does not include the tires being removed
I use ramps
If the vehicle is on asphalt, i use the plastic ramps
If it is on concrete, i can use either the steel or plastic ramps
https://allgaragefloors.com/5-best-car-ramps/
because i have the air damn, i have to use 2 X 6s to lengthen the approach angle
Then i scoot the wood out of the way to work on the truck
companies make floor jack extensions, i don't know how tight fitting they are
https://www.google.com/search?q=floor+jack+extension&tbm=isch&tbo=u&source=univ&sa=X&ved=2ahUKEwjFsfKXvcnfAhXFilQKHcArDk8QsAR6BAgBEAE&biw=1333&bih=655
You can also buy rubber pucks that give you some extra height
If you have the old packings(seals o rings etc..) You can send them out to get matched up.
1 - 10 of 10 Posts
