1 - 16 of 16 Posts
Just trying to put together a list of all our mods.
Might get me some more ideas.
My Mod List:
De-badged
A.R.E. Truck Cap
OEM Remote Start
OEM Mud Flaps
OEM Side Steps
OEM Fold Flat Floor
OEM Under hood light kit
Mevotech Upper Control Arm's
Bilstein Shocks
Tuftruck 1211 rear springs
Magnaflow 12388 Muffler
Kenwood DDX492
Alpine MRV-F300 Amp
Alpine SPR-6x9 (DOORS)
Polk Audio DB351 (DASH)
Stinger Roadkill Sound Damping
Cabin Air Filter
Painted Engine Cover
RMI-25 Additive
DIY Cold Air Intake Mod
H9/H11 Head Light Mod
Dome Light LED Mod
Husky X-ACT Floor Mats
AVS Deflectors
DZ Tailgate Assist
DZ Bedmat
Line-X w/UV
Traxion Tailgate ladder
Door Cup Holders
Wadestar Blindspot Mirrors
9' Antennae
Footwell Lighting
LEDGlow Tail light bar
RAM head logo Chrome Valve stem covers
Covercraft UVS 100 Sunshade
Disable Seatbelt Chime
Undercoating
Planning on;
adding USB ports to the sides of the back seat blower
Fold Down Rear Seat Mod
Paint underhood Fuse box and air filter cover
Installing RAM Air Type Wind Scoop for DIY Cold Air Intake
Forward facing camera
Holy Cow! You might need air bags to help hold up all that! For my Eco Diesel, only the GDE tune/computer flash.
Super Moderator
Line-X
Console Vault
Bilstein 4600s
Tuftruck 1223Vs
35% ceramic tint on the back and sides
70% tint on the windshield
Added OEM trailer brake controller
Huskyliner Wetherbeaters
Door edge guards
Coverking 100D Cordura seat covers
Corsa catback
KO2s (stock size)
BT catch can
Plastidipped console trim ring
White Ram decal on center stack pen tray
Cabin filter kit
PIAA Ion Yellow fog bulbs
H9/9011 bulb swap
Powerstop brakes
"I'm keeping it stock"
I think that's it
Silverstar ultra bulbs, new light fixtures
Kicker stage 1 with amp
AEM Wideband failsafe
Mopar floor mats
Sun shield for bright days(USA flag)
Stubby antenna
Front tint matching the back windows
Factory bug deflector
Factory tonneau cover
Factory bed liner
All possible factory options for the year except 3.92 gears
Bilstein 4600s
Custom made torsion bars and rear leaf packs
Poly bushings in the rear only
Hellwig front and rear sway bars and poly bushings
Upsized swaybar links with grease fittings
Moog premium front control arms with grease fitting and press in ball joints
Moog front hubs with mopar CV axles
2 inch lowering keys and shackles
Maval power steering rack plus inline filter
Soild power steering mounts
Fully sandblasted and preped frame, all new body mounts and misc hardware
Two coats of self etching primer, two coats of rustproof MD UV proof paint
Stock evap system and harness
Fuel tank with fuel module system fit with a 950hp full system with full return and cooler
AN based fuel feed and return system integrated into new holders/brackets
Powerstop parking brake setup
All new parking brake cables
Powerstop Z68 brakes, calipers, performance rotors and a 3500 hydroboost system
Fine-lines full custom stainless steel brake lines
Pentosin German spec DOT 5.1 brake fluid
Pacesetter headers, stripped and repainted, fully wrapped and painted wrap
Custom midpipe with one magnaflow 150 cell 4 inch cat on each bank
Magnaflow X-pipe/muffler unit
MBRP axle back minus muffler duel side flare exit, one each side
Rebuilt transfer case and axles
Performance built 48RE transmission in a stock 46re case will all billet internals
All alto red eagle trans clutches, Kevlar bands
Performance valve body tuned for shift speed and firmness, all billet parts
Deep trans pan from mag hytec with magnets and drain, add on temp sensor
Billet TQ converer from PATC with hand toleranced pump and 2600 rpm stall speed
Store brand ATF+4, possibly will move to something better
All new sensors and senders for every system on the vehicle
1996 dodge van engine block with 89000 miles
Full blueprinting and basic prep of said block, magnaflux tested and acid washed
All bores line honed to perfect true, cylinders pressure plate bored and honed +.030
Deck machines perfectly flat and to zero with a surface finish for Cometic MLS gaskets
All ARP studs for mains, heads and rods
Scat 4340 full forged rotating assembly with dished forced induction pistons
Above assembly is +1.2 grams front plane and +1.5 grams rear plane balance
Crank is fully worked over with knife edging, fillet radius, and oil passage work
Rods are shot peened resized with celvires H bearings
Main bearings are also H celvites and mains are like honed
Main stud girdle
Brass freeze plugs and hex head premium galley plugs
All felpro seals except mains and head gasket, national and Cometic for those
Edelbrock CNC stage 1 heads with Hughes engines shaft mounted 1.65 rockers for magnum heads. Hand polished chambers and 3 angle valve job
Total seal custom ring pack, steel top ring with no coating, Napier second ring, and mid tension oil control rings all hand gapped for forced induction
Melling high volume oil pump, hand clearanced and match to the rear cap
Factory oil pan with baffles added
Amsoil 10w-30 Z-rod oil, Ford 300 oil filter
Comp cams custom ductile iron roller cam with 228/242 [email protected] .050 lift with .587 lift intake and exhaust with 114 LSA and profile optimized for supercharging
Comp cams hi-tech series heat-treated one piece chromoly pushrods
Crane anti-pump up lifters with factory dog bone system
Springs and stuff that match the cam, valves are some crazy heat resistant alloy I forget right now
Mopar M1 FI two barrel intake with heavy porting that is blended into the heads, turtle on the plenum floor
Holly duel 52mm TB that is heavly blended and ported into the intake, heavy spring for better petal control. Mopar IACM and TPS sensors
TB spacer out of nesscesity due to fuel rail hight
Custom CNC billet fuel rails with individual AN-8 feeds and AN-6 returns linked into an aero motive boost referenced fuel reg with mechanical failsafe
61 lb/hour semmens DEKA fuel intectors, bench tested and flow matched
Mopar performance valve covers
Mopar performance distributor drive gear and distributor
MSD coil and 8mm wires, BWD cap and rotor
NGK super secret lawnmower plugs that play well with hot combustion chambers
AGM battery, 850 CCA
Power system relocation to front passenger side of bed, remote posts in engine bay
Flowkooler high flow/high speed water pump
180 degree, flow balanced type GM small block thermostat (intake was modified to fit this unit)
SFI crank pulley/damper
Bosch alternator
1 gauge heavy ground wires
Flex-a-lite E-fan and controller board
Stock replacement radiator (doesn't work lol), going to be a custom unit soon
Stant radiatior cap rated at 20lb system pressure, mopar coolant used since I don't like how clear G05 is dyed even though they are the same thing......
Orange ceramic paint for the engine and trans, heads are left bare aluminum as is the water pump and alternator. Brackets are high gloss black. Transfer case and front axle are silver ceramic as are the driveshafts, rear axle is same paint as the frame.
R/T badge
I think that's everything, I am sure I missed something though.
Pedal commander ( set to Sport + 4 )
Silverstar Ultra headlights and fog lights.
5% tints on all windows except windshield.
Factory 20" wheels powder coated wet black.
Dual Liner.
DeeZee tailgate assist.
Debadged RAM 1500 on both doors.
Debadged 4X4 on tailgate.
Replaced both Hemi badges and front and rear Ram sheilds with OEM blackout badges.
Muffler delete.
Lots of elbow grease keeping her washed and waxed.
I think thats it for now.
Far from done though.
Oh lord...I've had my truck for almost 13yrs...let's see
Superchips tuning
Airaid intake
Taylor shorties
TM mod
Sonnax line booster
Power wire
Upgrade from 136a to 160a alternator
45° oil filter adapter
Britebox (keeps high beams and fogs on with low beams)
1 ton trans cooler
Bumper grille
SRT hood
SRT door panels, lock pins and dash center bezel
RAH code MP3 CD player with sat radio/phone adapter
Aeroforce Interceptor gauge in SRT A pillar pod
EVIC upgrade with longer overhead console (has sunglasses holder)
Hemi Sport chin spoiler
Hemi sport running boards
Tow mirrors
Rear fender liners
Extang revolution tonneau
06-08 tailgate spoiler
Switched from polished flower petals to 4th gen chrome clads to polished 4th gen sport wheels; variety of different tires over the years lol
SRT-10 front 4 piston brakes/15" rotors (with spindles)
SRT-10 reg cab coil springs with SRT Bilstein shocks
2800 Circle D converter
PML deep pan
38mm front sway bar
Custom driveshaft
SRT-10 Dana 60 4.56 rear with SRT-10 brakes and SRT Bilstein shocks
Belltech rear sway bar
Borla catback
Removed the original nerf bars, bed rails and mud flaps.
Hopefully winter project stuff that will get completed (since I shouldn't need it to tow the boat or anything):
05 PCM/harness conversion
06+ coil conversion
Fix the TCC solenoid problem
Eagle heads
KRC 210 cam
Eagle truck intake
4th gen Vararam mated to scoop in SRT hood
Headers and Y pipe
New carpet
4th gen seats
Finish 4th gen console and shifter install
04-08 steering wheel conversion with Grant wheel
In almost 2 years of ownership:
Shorty antenna
Dash Cam
Wade Star Phone holder
Wade Star convex mirrors
Tonneau cover
Load bar (el cheapo Harbor Freight one)
AFE air filter
HVAC air filter (should have come standard!)
Cooper AT3's
It's just about perfect for my use. Would like some OEM fender flares to dress it up just a tad.
Diablo i2010 i2 DCX tuner with custom 93 Octane HemiFever Tune
Pedal Commander
Stant 180-degree thermostat – 48798
Mopar Performance cat-back exhaust - P5155280
Moe’s Performance 85mm ported throttle body - 85MMTB
K&N cold air intake - 63-1561
MOPAR remote start (dealer installed)
Michelin P275/60R20 BSW all season tires
Billet Technologies custom red engine bay covers
Black tubular step bars
WeatherTech floor mat
LineX spray bed protector
Truxedo bed cover
Rubber bed mat
Bosch Icon windshield wipers
Clazzio dark grey leather seat covers
MOPAR pedal kit
MOPAR cabin filter conversion kit
Stubby antenna
Sylvania zXe headlights and fog lights
Some Assembly Required
Oh geez...you asked for it lol
1. Total Load Control (replacing with Firestone Ride-Rite soon)
2. AutoMeter Steering column gauge pod.
3. Glowshift air pressure gauge
4. Glowshift voltmeter gauge
5. Rough Country Mesh Grille
6. 6000k HID lows in projectors from RetroShop and XenonDepot.
7. 3000k HID Fogs from Xenondepot.
8. LED Bedlighting
9. 52" curved LED bar on front bumper.
10. 24" straight LED bar on front bumper mount.
11. 2x 4" LED pods in front
12. 2x 4" LED pods mounted under rear bumper
13. TygerAuto StarArmor tubular rock sliders (side steps)
14. Bushwacker pocket style fender flares
15. Plasti-dipped chrome
16. AVS in-channel ventvisors
17. Custom wiring harness and carbon fiber toggle switch panel w/blue LED toggle switches.
18. Custom fuse block for accessories.
19. Gray interior trim color matched in PCL "Blue Streak Pearlcoat".
20. Calipers painted PCL "Blue Streak Pearlcoat".
21. AFI Cold Air Intake.
22. Mufflex Muffler Delete.
23. Billet catch can.
24. Wired for winch control at rear bumper for hitch-mounted winch.
25. TruXedo TruXport roll up soft tonneau.
26. Taillight guards.
27. Mudflaps.
28. Burnt Stainless (blue) 4" Exhaust tips.
29. 33x11.50x20 Firestone Destination A/T.
30. AVS bug shield.
31. Bilstein 5100x front shocks set at 2.8
32. Bilstein 5100 rear monotube shocks
33. Mopar Ram's head Fuel Door
34. DeeZee tailgate EZ down
35. 5% tint over factory rear, 20% front.
36. .50cal antenna
37. Pedal commander
38. Mopar stainless door sill plates
39. Mopar spray in liner
40. Powerstrop Drilled/Slotted Rotors with EBC Green Stuff Ceramic Pads.
I think thats everything...lol
Duratracs 325/65/18
18 inch black wheels
Tonneau that I hate
Side steps
bilsteins at 2.8
1.5 rear spacer Maxx suspensions
Air box mod with Green racing filter
Blacked out emblems
Carven Progressive
Tint
Tailgate assist
Bedrug
Pedal Commander
I haven't had my truck a year yet, but I don't think I can remember all of my mods...
9-Drive (Chinese Pedal Commander)
K&N CAI
Bilsteins set at 1.4"
MBP Caliper covers
8.4 Radio Upgrade
Steering Wheel Audio Controls
7" Premium Cluster upgrade
Auto Dim and Auto High Beam mirror
OEM Backup Cam
OEM Black Housing Headlights
H9/H11 Headlight upgrade
Sport Grille insert
Hella Supertones
Painted powerfold mirrors w/ turn signals
Painted Door Handles
Added Hemi Dual Exhaust
Painted dual cutout rear bumper
Sport Wheels and BFG's
Backflip Tonneau
Swing Box
Upper Glove Box w/ door
Underdash lights
Underhood light
Deezee Tailgate slow open
OEM Hitch
OEM Nerf Bars
Low Profile In Channel Vent Visors
40% Carbon Tint
JBL Club Dash Speakers
JBL Club Front Door Speakers
Heated Front Seats
Remote Start
Tinted Taillights
Matte Black Decals over emblems
Superchips tuning
Airaid intake
Taylor shorties
TM mod
Sonnax line booster
Power wire
1 ton trans cooler
Bumper grille
SRT hood
Tow mirrors
Rear fender liners
PML deep pan
38mm front sway bar
Custom driveshaft
Borla catback
06+ coil conversion
Eagle heads
KRC 210 cam
Eagle truck intake
Headers and Y pipe
New carpet
4th gen seats
Move 04-08 steering wheel conversion with Grant wheel to completed list lol
Premium Member
8. LED Bedlighting
27. Mudflaps.
30. AVS bug shield.
36. .50cal antenna
37. Pedal commander
Sounds like a heck of a list!
Any chance you have some pictures of those HID lights in action? We always love to see our kits out in the world.
~Robert
  • Carven Exhaust
  • Debadged
  • Speakers
  • Tint
  • Hellwig Sway Bar
  • OEM DRL's
  • DIY Grille Lights
  • LED Fog Lights
  • Lamin-X Fog Covers
  • 15" Antenna
  • AEM Dry Filter
  • Tonneau
  • Cargo Extender
  • TS Stall Mat
  • Husky Mats & Mud Guards
  • Bayou Goat Mount
  • Anker Dash Cam
1 - 16 of 16 Posts
