1 - 3 of 3 Posts
i was wondering why on ebay and many other sites that sell wheels for rams 2003 and up say that they will only fit those years. just recently i saw a 2001 body style 1500 driving down the road with the 2006 20" OEM rims on it. i thought they couldnt fit on it. did the guy mod his truck to get them on or will it fit. ive seen online that the 2001 to 2006 rams all have 5x5.5 bold pattern. so will the new rims fit on an older ram? help me out.
G
Here's some wheel specs for ya to peruse:
Wheel Specifications:
1994-1999 1500 2WD/4WD Aluminum Wheels
• Lug Pattern - 5 on 5.5", 1/2" bolt
• Rim Size - 16x7.0"
• Offset - +13.97mm
• Backspace - 5"
• Max Tire Size -
• 15x8.0 rims with 3.5" backspace will fit, but they stick out of the wheel wells.
Torque Spec
• 80-110 ft lbs (108-150 Nm) on 5 stud wheels
2000-2003 1500 2WD/4WD 17" Steel Wheels (Chrome or painted)
• Lug Pattern: 5 on 5 1/2
• Rim Size: 17x7"
• Fits 94 and up 1500 trucks
2000-2003 1500 2WD/4WD 17" Aluminum Wheels (posted to DiRT by Mat Felthousen):
• Weight: 23.5 pounds
• Rim Size: 17x8"
• Actual width edge to edge: 9 1/16"
• Backspacing: 5 9/16".
• The space from the outside edge to the mounting surface (against the rotor) is 3 1/2".
• offset calculate: 1 1/32"
1 - 3 of 3 Posts
