1 - 3 of 3 Posts
Hi I'm looking for some info on wheel offset and backspacing. I have a 2014 ram 1500 single cab short box 4x4, I want to put the Bilstein 5100 struts at the 2.1" and I would like to run 295/75R17 tires. (or bigger if I can fit them), I would like to have 17x9 rims but I'm unsure about the backspacing and offset, I would like it to stick out from the fender a little but not too far that I need fender flares. I was looking at rims with 4.5 backspace and -12 offset. not sure if that is too much or not enough. If someone can please help me with this.
:4-dontknow:
Because your going with a wider tires u might be good with a 0 offset I'm not sure about about 14' but the 09-12 20" rims have +18mm so -12mm may stick out more then u want
1 - 3 of 3 Posts
