Wheels and tires
839 6
Ive been looking at different wheels to run. The tires will 13" wide, but the rims will be 9" wide. all 17" rims Ive found are 9" wide max. how much of a problem is that going to be for the tires? I am looking at a set of M/T Classic Lock Black
http://www.ntwonline.com/Mickey-Tho...lack-Mickey-Thompson-Wheels.html#.T3OlmGHCmKw
1 - 7 of 7 Posts
Hi Dirty, that should be fine, check with the tire manufacturer. I just purchased 35"X12.5"X17" and the recommendation was not to go below a 9" rim but it would be ok to that point.
I had 325/60-18 Nittos on my stock Titan rims (8") wide and they were fine. Looked awesome with the little sidewall bulge, no uneven wear or anything and those tires were 13" wide and called for 9" rim minimum. You'll be fine
i see you ended up ditching the titan for a dodge.
1 - 7 of 7 Posts
