1 - 2 of 2 Posts
I work for a car dealer and know where the diagnostic ports are on most vehicles. I brought home a scan tool to check codes and I can find the port.
I need to see if I have any codes because I am having spark issues. Anyway, I went under the dash, even removed the shin panel and not port. Couldn't find anything online, looked under the hood, by both fuse boxes and nothing.
I have a 360 V8 Extended cab 4x4.
Any info will help.
Thanks, David
:4-dontknow:
sorry my friend you dont have an ob2 port to early they came on 96 and later, a select few got this pre 96. you should have the old chrysler connector next to the fuse panel under the hood or near the computer. any garage with the snap on scanner exspecially the old red brick one will have this connector and yet it will only give you a code and maybe a little bit of data.
1 - 2 of 2 Posts
