1 - 20 of 26 Posts
Looking for the VIN lookup/decoder and can't find a actual useful link
Any help would be great.
Looks like Ram has made some changes and updates :smileup:
Go here;
https://www.mopar.com/en-us.html
You'll have to make an account if you do not already have one.
I was just there, and honestly it's more user friendly then the
last version.
After you log on, Click on ' My Vehicle ' then click on ' Dashboard '
on the lower left click on ' Vehicle Equipment ' Factory installed
options will appear under the ' Other Category '
Discussion Starter · #3 ·
Ha ha ha. This is a sticky?!?! My first sticky in any forum ��
Thanks for the help I'll give it a go today !
Discussion Starter · #5 ·
Are you looking for the page to get your build sheet?
Yes!! I can't find it. That link worked tho. It doesn't show everything I don't think.
The sticker on window says the new truck has unconnected 5.0 with hands free however the equipment listing says 3.0 u connect. So now I'm confused as to what the new truck has
Apparently they have shuffled some shit. Give it a while, they usually fix it within a month or so. Alternatively you could ask a dealer, they can run your VIN.
Discussion Starter · #7 ·
Update..... the dealer gave a FULL print out and its quite extensive. As for the link I used for my 2016 build sheet I have no idea where. When someone finds the current working links please post here ;)
Premium Member
My Build Sheet, also so the Equipment Sheet is 3 pages long, it covers everything that came on it from the factory
It does not have the alternative options, just what it really came with
First go here
https://www.ramtrucks.com/webselfservice/ram/
then look for the words YOUR VEHICLE, then EQUIPMENT LISTING
clicking that will open a new window & you need to insert your VIN#
Discussion Starter · #10 ·
It worked for me too!!!! Thanks guys! That's the link I had for my last truck. As for iPhone users when you click the link it'll open a page asking for U.S or Canada. On the top right corner you'll see a X. Hit that to close that page. If you hit the links it'll take you home page for Ram.
On the left you'll see equipment. Enter vin.
Old thread I know, but what happened to the link where you can order a print manual/glove box materials? Just says OOPS bad link.
OWNER'S MANUAL AND GLOVE BOX MATERIAL
Oops... Looks like you found a broken link. We have notified the appropriate area to investigate and repair the problem. Please try again in a few hours.
First go here
That link worked perfect for me....Thanks!
First go here
this one has seemed to have been relocated or removed all together. it does a redirect now. I used to use it OFTEN .. daily .. when online searching for a new truck. In Canada many dealers don't post all relevant info (or use generic images). this told me everything I wanted to know before I had to deal with a salesperson or a dealership. ie. bed length, gears.. just as two examples.
edit: actually for now Lizard is correct. if you click on the link that takes you to his PDF, you can alter the address with a new vin in the address bar and get another vehicle pulled up. a work around for sure. thanks..
https://www.ramtrucks.com/webselfservice/BuildSheetServlet?vin=1C6RR6NT6DS706281
This is the link I have saved for my truck, can probably swap the vin and get yours too.
if anyone has an updated link to this tool that would awesome! .. thanks!
1 - 20 of 26 Posts
