1 - 4 of 4 Posts
Discussion Starter #1
My 2013 Ram was upgraded from a Uconnect3.0 to a Uconnect5.0 radio system before I bought it from my son. It was done before he bought it.
When I start the truck, the radio turns on, no matter if I had it off when I last shut it down. When the radio is off, it always turns on when I shut off the truck. I haven't found a solution in the owner's manual. Does anyone have this problem? Better yet, has anyone fixed it? Share your knowledge, please. Thanks, Ram guys and gals.
That’s the way the radio was designed. You can’t change it. If you don’t want music when you start the truck the radios volume needs to be turned all the way down before the truck is turned off.
What NevadaMike said.
When you push what you think is the on/off button it does not turn the radio on or on, it merely mutes it.
The design must have been changed in later model years as my 2010 Laramie has an on/off push button knob. The radio will stay off with a blank screen until I manually turn it on.
1 - 4 of 4 Posts
