1 - 3 of 3 Posts
Hey guys,
I've got a stock 2005 Dodge quad cab 4x4 with 20 inch rims. I am wanting to go to the atx 18 inch crawl wheels. I can't figure out what to do with the tires though. I thought about doing thnitto terra grapplers but I don't know if I will like the 275/70s. I looked into the 295/70s but it shows they are about a 35 inch tire and almost 12 wide. Does anyone know if they would fit on a stock ram since the crawls have no offset to them either. Also, I thought about leveling the front end, would that make them fit better if they don't at stock?
Leveling it out they will definitely fit.. If my lvl doesn't get here soon then I will be finding out if 35's will fit on stock ride height though. I am sure they will fit but there will more than likely be some rubbing at full lock and possibly before that. It is usually safe to say that once you start going above a 33 or 34 then you probably want to start raising the truck up some.
1 - 3 of 3 Posts
