1 - 4 of 4 Posts
Discussion Starter #1
It started with a leak, and the driver's side washer wasn't spraying. I could see the washer fluid running out of the hood insulation. Today I removed the insulation, and found both of the squirters brittle, and removing the hose was enough to break them both. Is this a common issue? Removing them wasn't a problem. They both just about disintegrated.
Thanks!
I've noticed mine don't spray when I try to spray the windshield, but I haven't looked into it to see why. When I get my truck back I'll see if my problem is the same as yours.
Discussion Starter #4
Originally I thought maybe the pump had gone bad, but when I opened the hood and tried them again, I could see where the washer fluid was running out from above the hood insulation.
1 - 4 of 4 Posts
