1 - 3 of 3 Posts
Discussion Starter #1
I have a 2013 Ram 1500. Went to pull my trailer and plugged in the lights. No Lights...I unplugged the trailer and the plug on the truck fell apart. I unplugged the socket and replaced it. Lights were working fine hooked to my other truck. When I unplugged the socket from the truck it was full of water. I think that plug is shot. Does anyone know where the other end of that plug is and can you buy that section on the harness?
Thanks in advance
Polar Bear
Premium Member
So you took the plug out of your trucks bumper ?
now the wires are just hanging at the back of the bumper ?
You can buy a connector & plug the wires into it, usually just takes a screwdriver
You should be spraying both trailer connectors with a product like CRC Electronic Cleaner or some other Contact Cleaner like Gunk & 3M
The connector that is in your bumper has a 7 pin & a 4 pin connector
Etrailer carries the part
https://www.etrailer.com/Custom-Fit-Vehicle-Wiring/Ram/1500/2013/A10-7072VP.html?vehicleid=201363841
1 - 3 of 3 Posts
