Hello. Was told this is the right place for this?
Does anyone know the proper way to flash / recalibrate an ABS module using witech? Is there a sequence or something? Like flash the ECU and then immediately start ABS initiation? Asking because I did a battery
ADVERTISEMENT
pull and then all my ABS light came on at about 10 miles an hour. Speedo was off by 10 to 15 miles an hour. Figured it just needed to be flashed. Took it to the dealer. They flashed it but It didn't help. They put a new module in and flashed that one. Same thing. wheel sensors good, all connectors good and line noise / resistance is good. Codes come back as left rear wheel inconceivable data, right rear wheel inconceivable data and ABS module inconceivable data. When tracking with a starscan front wheels are tracking same speed and rear wheels are same speed just the rear wheels are together 15 miles slower. I figure they're just flashing it wrong or if anyone else knows a way to program pinion settings that don't involve the witech for a 2009 Dodge Ram?
ADVERTISEMENT
