1 - 1 of 1 Posts
My question is this, installing air horns basically you cut the plug to a regular horn and plug in the compressor, unfortunately it killed the power to that horn ,how do you fix that and should I do the other wiring and put the relay( like when adding off road lights)in ..I am a little confused cuz it should have been very simple.. I believe the compressor tripped whatever the problem was because it sucked too much juice through it and the original horn must be a low voltage unit..according to Wolo, I should have switched the non-alarm horn with the relay.. hopefully I can reset the horn module and see if this works..
1 - 1 of 1 Posts
