1 - 6 of 6 Posts
Have a 2011 Mega Cab. Wondering what will happen when I put on my Lance cabover camper? Will this block reception and is it possable to add another antenna (magnetic) on the hood or front of roof?
The camper is likely nuke your Sat Radio, but your GPS will be fine. It's antenna is in the dash right above the instrument cluster. :)
Premium Member
If you mount a cab over camper, you will need to do a windshield mount antenna
You will find that the windshields angle will give you better reception, even with the camper off. Less interference from big trees & bridges. Mount it low & in the corner of the glass. don't put it close to your am/fm antenna for best reception
they make glass mount xm & sirius antennas
http://www.myradiostore.com/antennas-cables/for-inno-helix/glass-antenna.html
Sirius Interior Glass Mounted Antenna, named SIGMA
Glad you posted that !
I am in the process of looking at a slide in camper I never even thought of the Sirus antenna location. How difficult is it to get to the radio antenna what dash piece's do you remove ?
Premium Member
It depends a lot on your cab, if you have the buckets & full floor console with the shifter on it, it comes apart different from the bench seat with the shifter on the column, but not much
First of all you need your sales code for the radio, most times on the newer Rams, it is found on the radio face, lower right hand corner, 3 letters
Next go to this site, click Dodge, then type in your vehicle info
then scroll down to the radios Sales Code
start reading, & then click MORE INFO, you will find installation & maybe even the radio Manual. It is the best site that i have found for our Media Center MYGIG radios & others
http://www.oemautopartsco.com
1 - 6 of 6 Posts
