Old 11-20-2011, 07:12 PM
JasonK94Z JasonK94Z is offline
Vehicle: 2011 Dodge Ram Outdoorsman
Trim Level: Quad Cab Outdoorsman
Rep:30
JasonK94Z is on a distinguished road
Exclamation Surging around 35-40 mph
Cruising in the truck in 5th gear around 35 to 40 mph, and the truck surges. Sometimes it finally makes up its mind to downshift to 4th, others it just continues to surge.
Anyone else had this problem? I think I may have read one time about a drivability flash for this?
2011 Dodge Ram Quad Cab Outdoorsman
Old 11-20-2011, 07:45 PM
wbowyer wbowyer is offline
Vehicle: 2011 Dodge Ram 1500
Color: Inferno Red
Rep:71
wbowyer will become famous soon enough
What gears do you have? Have you put bigger tires on the truck? I know my 2500 which had 3.55 gears had shifting issues at about that same point because its right there between the high end of the lower gear and the low end of the higher gear, causing the tranny to "hunt" for the right gear.
There are a couple of fixes, the most reliable being a shift kit.
Old 11-20-2011, 07:51 PM
Rep:30
I have 3.92 gears, and the all terrain tires that come with the Outdoorsman, so factory size tires.
Old 11-20-2011, 07:58 PM
Color: Inferno Red
Rep:71
I'll see if I notice it next time I'm in my truck, I have the same gears and tires. Does it do it when you select 4th or 5th gear?
Old 11-21-2011, 10:11 AM
cwsomerton cwsomerton is offline
Trim Level: TRX4 Off Road
Color: Black/Grey
cwsomerton is on a distinguished road
My truck also does this, both my bros have 2011 outdoorsman's and they also do the same thing. I am wondering if it is somehow related to the star case out for the torque converter? Is it possible it could be at the point where in locks/unlocks constantly?
Old 11-21-2011, 10:40 AM
Rep:30
I have the selector in 5th gear to avoid the 4 cylinder deal.
Old 11-21-2011, 08:28 PM
justin0388's Avatar
justin0388 justin0388 is offline
Vehicle: 2011 Ram 1500 Express
justin0388 is on a distinguished road
It doesn't have anything to do with the torque converter, I had the surge before and after. Mine doesn't surge too bad though, it does it right around the time it drops down a gear. I have the same gears in mine too with stock tires.
Old 11-22-2011, 09:40 AM
Ramathorne Ramathorne is offline
Vehicle: 2013 Dodge Ram 1500 Quad Cab
Color: Mineral Gray
Rep:54
Ramathorne will become famous soon enough
Mine does it...And does the tranny confused shift too when passing (when I floor it)...
