2004 to 2004.5 5.9L engine difference?
11K views 4 replies 3 participants last post by  Mvigo
#1 ·
It is my understanding that there is a difference in the 5.9L engine after 2004.5. If I am correct, what is the difference? Is the 2004.5-2007 better then the prior version? If so, why? Actually, a friend tells me the 2004 version is better on fuel economy but I can't find that written anywhere...
thanks in advance...
#2 ·
turbo, injectors, pistons, ecm/pcm, cat are all different.
turbo is bigger on the compressor side allowing slightly more boost.
the injectors have a different hole count/spray angle for emissions purposes.
the pistons to work with the injectors.
the ECM is stronger/faster.
the 04.5 has a CAT the 03-04 do not.
#4 ·
The 04.5, which were built after Jan 1, 2004 have a third injection event which can hurt fuel economy slightly. The early 04's have only two injection events. The early ones have a reputation as having better fuel mileage, but if I were looking, I wouldn't worry about one over the other.
