DEF Gauge Stuck? Possible to Overfill?
1 reading
24K views 13 replies 13 participants last post by  nichbeau77
#1 ·
How long should the DEF stay on 100% full? 2 tanks of diesel & it has not budged. When got from the dealer it was 1/2 full & I could watch it go down accordingly. When I filled up the DEF I did it a truck stop, whereas the DEF there is half the cost if buying elsewhere. I am wondering if the pressurized fill nozzle at the truck stop may have overfilled & jammed the gauge? :4-dontknow:
#10 ·
I had a 2017 ford dually that traded of at 37000 miles for a def heater issue. Traded for 2021 ram dually five miles from dealership derate warning came on. Dealer said first def pump froze now saying just overfilled. In studying this found a you tube video. Motor city garage I believe that has a video with a pump removed and a simulated def tank.
Def is corrosive to metal, manufacturers are using sonar gauges to conquer this problem. When the tank is full will be def above the sonar and it will not start reading until it is exposed to air.
As far as ram goes dont know. Drove the ford home just with dealer plate
#5 ·
DEF tank i believe holds 8 gallons
8 gallons should go about 10,000 miles
when you have about 9,000 miles, you should get a warning
let it get too low & you will be walking to find some DEF
  • Like
Reactions: DewayneK
#6 ·
DEF gauge
I bought a Ram 3500 dually about a month ago. I have about 1400 miles on it and the DEF gauge has not moved off FULL. I was worried so I bought a gallon of DEF and put it in. I almost had the entire gallon in when the filler tube overflowed. I guess I still had plenty in the tank. I was just concerned after reading about the cutbacks if you run out.
#7 ·
I hope you washed off the overflow quite well, I hear its quite harmful to vehicle paint.
Also I have yet to find a truck stop with a filler- is it just like a gas(diesel) pump? If so, does it auto turn off when the DEF tank is full?
#8 ·
It hardly moves at time and then other times it goes quickly. I have not figured it out quite yet, but I'm sure you gauge is working fine.
I pull a trailer and when I do this the gauge hardly moves, this is because the engine is burning up the fuel better than when driving pulling nothing. That I figured out so far :)
#11 ·
I had a problem with the DEF gauge showing dead empty when I overfilled the tank a bit using a DEF pump at a gas station (2018 Ram 2500). It also threw a check engine light but gave me no derate warning. After draining a gallon or so out, the gauge worked fine and the check engine light was able to be cleared. Before I did that, I stopped in at the dealer who told me I needed a new sensor and pump to the tune of > $2,000. I fixed it easily myself with the help from a Youtube video on how to drain the DEF tank and the price of some tubing and a primer bulb. Lesson learned and, needless to say, I won't be trusting that dealership with my business ever again.
#12 ·
Nice video , thanks for the info . I am very hesitant to trust any ram dealer, lots of misinformed advisers or just plain Lies .
