Drivers Headlight Goes On and Off Randomly
25K views 7 replies 5 participants last post by  Mr. Magoo
#1 ·
I am having a problem with my drivers side headlight randomly going off and on. The passenger side headlight works fine all the time. It typically happens more when I turn my headlights on, sometimes it comes on and sometimes it doesn't. If I turn my lights off and back on once or twice it will come on or if I start driving it will eventually come on. It sometimes goes off while I am driving but not very often but will come back on within a few minutes.
It acts like a bad relay but with me having an 09 Ram, it uses the TIPM to control everything. Are there any relay's in this system? Any other ideas?
#3 ·
Next time the light goes out, try getting out of your car and hitting the light a few times with your hand. If it comes on from movement, it could be a bad wiring harness or connector. Had this problem with my 11 Ram on the passenger side. It was actually a common problem as I saw threads on this issue also. I ended up cutting the wires and removing the harness and splicing the wires together. Never had a problem again. Hope this helps.
#5 ·
There are videos on youtube that show you how to take the headlight out if you need help. Originally I checked the headlight connector, unplugged and plugged it again. Looked fine, but after a few months the problem started again. The second time I just cut out the connector and hooked up the wiring without it.
