If ou want better filtration, while still getting maximum air flow,
get a EcoDeisel/6.4 Hemi lower air box
2014-2019 Ram part # 68232657AC - Air Cleaner Body
parts.allmoparparts.com
and inlet,
2014-2019 Ram part # 68190706AB - Ambient Air Duct
allowing for much greater air flow
or, if you want insane amount of air flow, do this mod.
I took out the airbox to see how the intake tube fits at the fender and noticed that it's a really cramped area. So I decided to add another inlet tube to the bottom of the airbox by attaching 3" aluminum flex pipe using a modified 3" PVC drain grate (cut out the grate). I drilled a 3" hole in...
www.ramforumz.com
using this hose, connected to the new 3 inch whole you just cut in the bottom of your stock Air Box,
Our black neoprene aeroduct hose is designed for low-pressure air ducting applications such as cockpit cooling. It is wire-reinforced and rated to temperatures up to 300 F.
www.pegasusautoracing.com
to this scoop , mounted to teh side of your radiator,
forcing colder, outrside air into your air box, as you speed down the road.
Our inlet ducts are wind tunnel tested for maximum air flow with minimal drag. These very small rectangular air inlets are easy to mount in the smallest air dam, bumper, or headlight opening.
or, you can just buy a piece of crap K&M filter and feel good about doing something, to improve your performance that actually harms your truck and reduces its performance and life expectancy. Giving all those who have any knowledge of air filters, a chuckle out of your K&M Sitcker.
Up to you
