Hey guys, getting ready to do this swap on my 05 Ram,
All parts off a flood damaged hydralocked Eagle 5.7 out of a 2016 Charger RT, bought the whole motor with only 8500 miles for 600 bucks! Anyway I have a few of questions on swapping all of the top end onto my older 5.7 block, I have read alot on this but not alot of clear info, I will keep this up to date so maybe next guy can get a good parts list and it will be strapped on the dyno to get all tuned after, oh and I am doing cam swap of either custom 268 comp or go all out with the big SRT MAX cam at same time of top end swap. Along with other supporting mods such as 3k stall and trans shift kit.
1. First question, once I install heads using the thick .075 head gaskets for a reasonable ~11.1 comp do I need intake spacers to clear the engine casting over cam area?
2. Are there any easy ways to move my alternator and A/C compressor over enough to clear the front mounted throttle body without swapping to a car style timing chain cover or without spending $700 to buy the extended brackets from HHP
3. Do I need to run custom length push rods tailored to the thicker head gaskets or can I use stock Eagle push rods?
4. Would it be a huge restriction to use my square port long tube headers or does anyone make an adapter plate?
Thanks for any help
Thanks for any help
