The easiest way to try and find out if the oil you are interested in is a Group III Conventional oil being marketed as synthetic or if it is a true Group IV PAO and or Group V Ester is to pull up the SDS (Safety Data Sheet) this sheet should be available on the manufactures oil page for the oil you are interested in.
Here are two examples the first is the SDS sheet from Redline High Performance Series oil and the second SDS is from Redlines Professional Series oil.
Redline High Performance SDS: https://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=828863&Language=EN&IssueDate=5/11/2018&SubFormat=USDS
Redline Professional SDS: https://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=830999&Language=EN&IssueDate=3/26/2018&SubFormat=USDS
You will be looking at section 3 and if that does not give much information then look at section 15 which may have more information on the Safety Data Sheet. In the case of Red Line section 3 has all the information you need.
This is what you will be looking for: Distillates, petroleum, hydrotreated heavy paraffinic
If any of those items are listed in Section 3 then the oil is a Group III base stock, it may be blended with Group IV base stock as in the case of Redline Professional Series oil.
The Redline High Performance Series has no Distillates, petroleum, hydrotreated heavy paraffinic listed so it is a true Group V Ester base stock and may have some Group IV PAO in it.
I used 5w-40 for both series of Redline oil to compare.
Here is a link to Mobil One 5w-40 and it is a Group III conventional base stock:
www.msdsdigital.com
Mobil 1 Formula M 5W-40 MSDS | MsdsDigital.com | Search our SDS online database free | Material Safety Data Sheet
Mobil 1 Formula M 5W-40 MSDS | The new SDS required by OSHA are being added daily to check for a newer version of a safety data sheet search our free msds online database.
