Low Beams Not Working
26K views 20 replies 14 participants last post by  Johnnyblaze
#1 ·
Hello everyone,
I searched far and wide for other threads but didn't find much help. My low beams are not working at all. Both stopped at the same time. My high breams, DRL, signals, and fogs work. I tried resetting error codes. I tried changing the headlight switch. Tomorrow I'm getting a fresh pair of bulbs just in case, but wanted to know what else I should try. I did check fuses, but as I understand the low beams don't have a fuse. I still checked a few of them and they all look good.
Thanks in advance,
Trev
#4 ·
I'm unaware of any such fuse existing.
I tried resetting the TIPM today but holding the positive and negative terminal connectors together (off the battery), and that did not work either.
#7 ·
Took apart the ram today. The low beam connectors are getting no power. That is going to the BCM, located under the fuse box. Trying now to see if I can get any power there...
#8 ·
I am dealing with the same thing right now on my 2018 ram 1500 sport. I have power everywhere I'm supposed to and still nothing. I just cleaned all grounds that i found and yet still nothing. It literally has me stumped at this moment. I have also checked fuses, relays, all power connections and new bulbs. NOTHING. WTF. If you figure anything out, please post what you found.
#9 ·
Hello everyone,
Thanks in advance,
Trev
Did you ever get them to work because this just happened to me coming home in a dark road .. not good!!! My truck is a 2018
