Mechanic Code: P000B & P0016
5.4K views 3 replies 4 participants last post by  Thunderhorse
If it was ok to drive the truck after those codes trip, then tripping the codes wouldn't disable those features. They are there to protect vehicle components; if you keep clearing the codes then there is a good chance that the problem that is causing the CEL to come on will cause further damage to other components.
Fixing the issue(s) now will result in cheaper overall maintenance costs and less net down time
