Need more lift
1.7K views 6 replies 2 participants last post by  CheechDogg.0n37s
#1 ·
I have a 2015 Ram 1500 Express Crew cab 4x4 and installed the RCX 6” lift kit with N3 lifted struts. I put 37x13.5R20 on 20x12 -44 rims. I rub slightly and want just a bit more lift. Does anyone know how I can do that without having to do a body lift or make the truck ride like crap?
#3 ·
I have a 2018 with a 7" lift with 37x12.50R20s ..... It rubbed on the corners of the bumper and the rear on the pinch welds .. I had to do a SoCal Mod on it, did some cutting on the pinchwelds, folded them back and cut the front bumper ... don't be scared to do the same ... the only other thing is is doing a body lift which I am actually going to do at some point ... nothing wrong with a body lift , don't let the bad stories about body lifts scare you from installing one on your truck ...
#6 ·
Here are the pictures of how much to cut on the body mount brackets ..
The first pick is the driver side rear mount that just needed a small notch cut out. The front mount needed a larger notch
The 2nd pic is the front driver side with larger notch
#7 ·
Here is another picture with the 1.5" body lift ... but I would just go with the 3" body lift to make sure you have zero issues
