I loaded up a few extra rounds of firewood just to clean up the log I was cutting the rounds out of. Normally I just load it to bed level but I went a little higher yesterday as you can see in the pic. We got stuck behind a minivan full of Mexican housekeepers coming over the mountain doing 45 in a 55/60 mph zone. The truck was a little extra wobbly but I figured we could make the pass...
I kicked the big Hemi down and proceeded to make the pass. As is came up on 65 mph the truck was rocking back and forth so violently the stability control intervened and locked the brakes up slowing the truck immediately back under 60. Freaked everybody involved out. I did get around the van and they left me a wide berth the rest of the way to town. We decided that 55 was the max and that the PW sucked at hauling firewood.
It is a good inch or two off the bump stop still. I don't think it is more than 1500 lbs of wood, within a hundreds lbs I bet. My friend who was riding with said it felt like a skateboard, axles going opposite directions and the truck twisting violently back and forth. Neither of us are fans of stability control but his comment was that it was probably correct in that situation. I have no doubt that the truck was about a second from going completely out of control. I suspect from the outside they would testify we in fact did lose control.
I know the springs are soft but JEEZ guys. Be aware that a capacity load in your stock '14+ PW is potentially very dangerous at highway speeds.
