I did a search and read through alot of threads but want a few opinions for my truck here in the north east. I have read that the stock factory pads are semi metallic and I got 45k out of this first set and now am trying to decide if I should change to ceramic or stay with semi metallic.
My plan is to hopefully just have the factory rotors cut/turned and buy new pads but have read that ceramics are hard on rotors. Is this a real concern? I also read that if you do any towing stick to semi metallics. Is this true too? I use my truck as a daily driver and do not tow with it often, but i do own a utility trailer that I use when needed for yard work or moving etc.
I do like that ceramics supposedly have no noise and brake dust, but want opinions from others from you experience with either so I can determine what is really the better pad to go with. Also, how much does brand come into play or would pads from the local Advanced Auto do.
Thanks for all the help!
