21 - 40 of 68 Posts
Oh duh. That's right.:doh:
I'll do some searching and see if the same bulb is available for the 2010's.
Discussion starter · #22 ·
T.H. I didn't see a picture of your new lows and your new fog lights on together. How do things look with the white of the lows and the yellow of the fogs together?
As requested, followed by just lows for comparison, and lastly just fogs:
Thank you! When I was coming home from Lake Tahoe in a blizzard last Sunday I was amazed how much more visible the cars running a yellow type fog were in the snowstorm. You could also really tell a difference when a Subaru came by with yellow film vs a quality bulb.
I really like the white driving light for summer use and was curious how the yellow looked with the white lights. Based on that picture I will be picking up a set to run during the stormy season.
I would be interested to hear your thoughts on the set up after driving in a good rain and/or snow storm.
Thank you
Discussion starter · #24 ·
Coincidentally enough I have not driven through the rain at night or through any thick fog since installing them. When i do I will try to follow up with pics
Nice writeup. I contemplated changing the fogs to yellow bulbs, but I think I like having them white as an auxiliary light. I need to hide a pair of some yellow fog lamps on the truck for the snow/rain.
Discussion starter · #26 ·
I used to use the fogs to throw a little more light to the sides but now with the brighter low beams I have found that to be unnecessary
Thank you Kelaog and Thunderhorse for a great write up on this.:smileup: Just ordered my H9's and 9011's after months of contemplating HID's and LED's. Can't wait to get this mod done and reap the benefits!
Discussion starter · #28 · (Edited)
Well I finally had a chance to test these at night in the rain, and by rain I mean downpour. Say what you want about liking the yellow color or not but they definitely do the job. I am sure most of you know what I mean when I say the stock headlights seem less effective when the road is wet at night, making it hard to actually see the road. The yellow fogs add depth-that's the best way I can describe it-to the lighting. It doesn't seem brighter or to go farther with them on, but you can still see way better if that makes sense. I was able to do the 55mph speed limit in rain that was limiting most other drivers to 30 or so. I will be buying a set of the PIAAs for the Durango now.
I was pretty focused on driving so I did not get any pics unfortunately. Now I just need to see how these do in fog.
Hello - don't mean to bump an old thread, but not sure if a new one is needed.
Looks like TH and Kelaog are the resident bulb gurus and I'm hoping they'll see this ...
Picking up my 2017 1500 this week and want to know if the following bulbs are the right "type" (size, power/draw) and if they are an improvement over OEM. Specifically looking to replace the "low beams" first.
https://www.tirerack.com/lighting/d....jsp?ID=1133&autoMake=RAM&autoModel=1500+4wd&autoYear=2017&autoModClar=Crew+Cab
Thank you much!
Alright, well I was able to do this sooner than expected because I was able to get away from work early and my 9011 bulbs came in today despite being scheduled for the end of the week. The wife wants to go out of town this weekend so I seized the initiative and did them this afternoon. I apologize in advance for the lack of pictures but I was racing the sunset.
First, the bulbs I upgraded to. PIAA yellow fogs:
https://www.amazon.com/gp/product/B000H3WZJY/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Philips H9s for the low beams to replace the factory long life H11s:
https://www.amazon.com/gp/product/B003YMPN3A/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Philips 9011 high beams to replace the stock 9005s:
https://www.amazon.com/gp/product/B00480J5CW/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
And while I was in there I went ahead and put in some Philips long life turn signal bulbs to lessen the chances I'll have to go in there again just to replace those:
https://www.amazon.com/gp/product/B0087D9A7Q/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Second, some references covering removal of the headlights:
http://www.ramforumz.com/showthread.php?t=231019
And what this upgrade entails. This is kelaog's very good thread that covers how many more lumens you get out of this and how to trim the tabs to get the H9s and 9011s to fit. Admittedly I just pulled the H11s and 9005s and propped them up on my toolbox and eyeballed them; the 9011s were easy to trim with toenail clippers since the tabs were plastic, but the H9s had metal tabs that I had to go at for a few minutes with the needle nose vice grips. Note to self: get a set of files.
http://www.ramforumz.com/showthread.php?t=215104
The fogs were real easy, just crawl under the bumper and they're right there. Turn them counterclockwise and pull off the harness, install the new ones in reverse order.
Getting the headlights was a bit more of a challenge, I had to get the ball out of the socket that attaches the housing before I could swing the inboard side of the housings inward and lift up on the light to get that bottom screw out. It is long and the lights are much easier to get in than out. I did use a long 10mm socket for the bottom screw and a shallow one for the top one behind the grille. I do not have after pics yet, and I actually forgot to get highbeam pics last night with the old bulbs (I know, boo) but I was planning to do that tonight since I figured it'd be another wee before I got to install them.
BEFORE PICS:
FOGS:
LOWS:
Its getting dark now so I am going to go wine and dine my wife (she helped by holding the housings while I put the bulbs in) and get some pics while I am out. I will have them up whenever I get the opportunity
Hmmm , none of these options will fit the '16 . Just noticed that your Ram is a '13 ...but FYI
Discussion starter · #32 ·
The lights are exactly the same in a 2016 as a 2013; the reason they will not fit your 2016 is that you have a Laramie Longhorn which has projector housings instead of quads like the Lone Star does.
We would have the same bulb options if I had a 2013 Longhorn or if you had a 2016 Lone Star
Hey Gang,
Great information here and thanks to the major contributors! I won't mention any names.......
9011's on order and I am looking forward to "seeing" the improvement in lighting! :smiley_thumbs_up:
Pete
Same here. I just ordered the Sylvania bulbs from eBay; $47 for the low and high beams, this should be nice :)
Discussion starter · #35 ·
Be sure to let us know how it works out for you!
Much needed upgrade!
:smileup:
I have had the bulbs installed for a couple weeks now and the difference is well worth the minimal effort. The hardest part was dealing with the smell of the melting plastic as I trimmed the tab using a red hot razor blade.
The low beams have more distance than before by quite a margin. I liked the blue hue that my old bulbs gave the housing when the lights weren't on, but I'll trade the better lighting for the aesthetics.
The high beams now are actually useful; I felt that the previous high beams were almost not worth turning on because it offered a thin central strip of light that wasn't much longer range than the low beams. The high beams now rival those of my wife's Grand Cherokee, which I think has phenomenal stock halogen headlamps.
I have not been "flashed" at all. In the past I would occasionally get flashed, likely due to the whiter light appearing brighter at the headlamp but paling in comparison to the H9/9011 combo.
I left my fog lights stock for now as I'm contemplating adding some PIAA's to the front to handle fog and inclement weather.
Discussion starter · #37 ·
:smileup:
Great to hear they are working out well. Your low beams are actually brighter than your old high beams now so it makes sense that the whole assembly is much better.
I know a lot of people like blue light more, and I do like the color, but bluer light scatters a good amount more so yellower light really can be more effective even if the output at the bulb is somewhat lower.
I was actually reading an article on the upcoming 2019 Silverado that said in a comparison between the Silverado, Ram, and F-150 (all 2018 models) the Ram got a marginal score for headlights while the other 2 scored "poor" in the IIHS test. Now I am assuming they used the projectors to get those results, but still it makes you wonder how bad the others are stock.
That reminds me of another comment I meant to make regarding the PIAA fog lights. My wife had to fly back home for a funeral a little over a week ago, and flew out of Wilmington because it was a lot cheaper, but it was an hour drive there. Her return landed late, and around 11pm the fog can get real bad right along the coast this time of year. Apparently it was real foggy that night, and she sent me a text mentioning how much easier the yellow fogs ( that I put in her Durango back in June) made it to see in those conditions.
Discussion starter · #39 ·
I debated yellow fogs, wish I would have of but the others are in now.
I am WORKING on a backup light upgrade. Should know how it and if it works in a few weeks.
What others did you go with?
It takes like 2 min to swap fogs. You just have to reach behind the bumper, its like the easiest lighting mod to do
21 - 40 of 68 Posts
