I recently bought a 2010 Ram 1500 SLT 4.7L. I got a good deal on it cause the #8 cylinder dropped a valve seat and overheated blowing the head gaskets and busting the radiator top hose completely off the radiator. Anyway after replacing the passenger side head and the head gasket on the driver side and all the other goodies it has been running fine until recently.
Every time I crank it now it idles fine while in cold start but once it comes out of the auto choke the idle drops way down and it stalls. It will stay running if you keep your foot on the accelerator, but as soon as you take your foot off the gas pedal it dies. I was messing with it the other day and forgot to attach the pcv hose back onto the driver side valve cover before starting it and it ran great, just like it used to but as soon as I noticed the pcv hose wasn’t attached, I reached in and hooked it back up and instantly the truck died. Fuel pressure is about 60psi and the spark plugs, coils, wires are all new as well as EGR valve and a clean air filter is in. The only codes it has been throwing is P0300 random cylinder misfire, and recently P0307 misfire on #7 cylinder. Possibly a leaking injector on 7? Any help would be appreciated
