2" rear lowering springs
6.7K views 13 replies 6 participants last post by  JDA
#1 ·
I have a bone stock 2016 Ram 1500 and I want to level it by dropping the rear 2". Before I order the new coils, I wanted to know if I needed to order a panhard bracket or upgrade my sway bar? I'm really picky about the look and my fear is the axle will shift one way or the other and not be centered. I've never lowered a truck before so ANY input is welcomed. Thanks in advance!!
#2 ·
To keep the axle centered you will need an adjustable panhard bar or a drop bracket for it. You will also need adjustable or shorter sway bar end links to keep it level, but you dont need a whole new sway bar
#5 ·
Hellwig makes a popular adjustable link swaybar, and Spohn makes an adjustable panhard that negates the need for a bracket. Belltech makes a kit that has springs, shocks, and the panhard bracket
#7 ·
No, I just sued what was in the box. I don't think you need endlinks unless you go more than 2" drop. Now when I did the BT 2/4 drop, yes, I did adjustable endlinks and Hellwig endlinks.
Here is just drop 2" with the GF kit
#11 ·
You'll just hit the bump stops sooner
#14 ·
I lowered my RCSB four inches in the rear with shorter coils. I had the airbags installed at the same time. We pulled a heavy motorcycle for 600 miles. The first 300 I added air to the bags but with a 275 lb toung weight and nothing in the bed it wasn't necessary. On the return trip no air was added and the fender only dropped 1/4 inch. Never hit the bump stops. The front of our truck has 2 inch drop spindles.
