61 - 80 of 141 Posts
There is pressurized oil just as I said , it's what makes the lifters work, it just doesn't oil the roller part of the lifter or cam lobes, that's where the splash oil is supposed to lubercate which it doesn't at low rpm as stated in the video, he's talking about the failure of the splash lubercation...he just doesn't go into detail about the oil making the lifters work. If there was no pressurized oil going to the hydraulic lifters they wouldn't work...look up how hydraulic lifters work, Google it for a better explanation I'm just not explaining it well enough
Yes I agree it's high and it could be wrong...most of my other V-8's and I've had a few mostly Chevy small blocks ran 25 at idle about, of course all of those made it past 300,000 with much abuse... unintentional but still ...no lack of lubercation in those motors except when I forgot to check oil and ran out...then it still went another 100,000 miles...so point being no V- 8 should suffer this issue...it's really pathetic ... couldn't of taken better care of this truck and tomorrow I start tearing engine apart with 85,000 miles on it and 6 months out of warranty! Chrysler should be ashamed of this issue....but they couldn't give a __it..... anyways thx the info I do suspect my idle pressure is wrong....still not sure what lifters to buy....don't want to do this again in the near future.
Maybe I'll do a fix by adding oiling to the block and sell my idea and be Mr. Mopar? Lol
My oil pressure has always read low/mid 20's idle and 50 at over 1000 rpm. Since new.
Pretty standard oil pressures. Even the 38 at idle seems higher than normal for most motors now days.
Oh I failed to mention in my back yard sits a 2011 charger rt hemi with 120,000 on it, LIFTER FAILURE waiting to be fixed ..AND a Jeep Grand Cherokee hemi ...lifter cam failure 100,000 on that, so yes I'm stupid to keep buying these...but that was before I knew about the issue and I thought the issue was fixed by the 2014 year, plus I needed the truck for work and figured lightening couldn't possibly strike me THREE TIMES!!! So yes I should attack Chrysler how, but don't have the time plus is quicker just to fix them all then deal with a big don't give a crap corporation.....I should just tear down my charger hemi and make a permanent fix like I said before, document it all and help everyone else with this issue, and fix anyone's else motor for way less then the dealer charges?? Now there's a great idea if I can actually figure out a way to fix the issue? I'm a builder of many things so perhaps I can?
Do you idle a lot? What oil and filter? mileage between oil changes?
Seems odd for you to have 3 that failed unless you have just been really unlucky.
I wonder if knurling the lifter bores would work? I have done that on pistons skirts before to get them to live.
My 2016 is a really quiet motor, but I do only have 42k miles on it - though most of those are fairly hard miles towing a 5000 lb boat at 70+ mph and/or running fully loaded.
OK, so a guy posted a supposed "expert" engine builder who didn't even note the HEMI block has a dedicated oil galley for the lifter bores. I was trying to get someone to say where the "pressurized oil came from". No one would, or knew. Now I know, from another video that showed the lifter bores and the oil feed ports.
I wasn't interested in how any hydraulic lifter works - this forum is about how HEMI hydraulic lifters work. Because these have repeated failures, where there aren't reports of of other engine builders. So it seems HEMI feeds their hydraulic lifters like everyone else does - with a dedicated oil pressure galley, and the mystery of the failures continues. Obviously, there is something unique about HEMI's that cause this.
Yes BUT...the pressurized oil doesn't get pushed to the axle/ needle bearing of the lifter roller....that's where the splash oil from the crank is suppose to take care of....which it doesn't very well at low rpm due to the design of the hemi block...just has the guy in the video explains! It's not a mystery at all, it's just because the the cam and the crank are further apart in a hemi block ....no mystery....
I've just torn into my truck and have a brilliant plan to increase oil directly to the cam lobes...I will most likely make a YouTube video of my idea..but first need to do it to my truck and test it, it won't be overly difficult and I think it's going to be the fix!!!
I plan to install stock lifters, maybe hellcat non mds ones, already have a new non mds camshaft...will get my lost mpg back by adding shorty headers and a tune...plus the headers will take care of the common exhaust manifold leaking problem as mine was leaking for the second time, warped exhaust manifold/broken bolts!
Anyways I will help anyone who wants help adding oiling to their cam/lifters if my idea works...STAY TUNED
the crank splash isnt doing the work... those lifters are moving up and down fast, the oil is coming out. That pressure test is pointless. Explain WHY the mopar lifters do the same thing with the MDS non activating lifters? They have the holes there and they gush oil. I think if he spins the cam youd get a realistic picture of whats going on. Tony is clueless...
explain how simply putting new lifters and a cam in a 5.7 and its fine? it has to be the lifters failing due to quality...
someone expain why the two "non activating" mds lifters have the holes in them from the factory per bank?
when the guy does the pressure test, he is using Enginetechs(see above video) they all have the holes in them(non MDS versions) see above video. Is this Enginetechs "fix" for needle bearing wear?
Does the MDS need extra oiling? is the non mds engine building pressure and just running an open pressure relief valve constantly? I mean you can buy a 20% higher pressure oil pump.
Is this "mx enginnering" oil "loss" actually by design?
On a MDS engine is that oil supposed to lubricate the cam? Oil would be everywhere if the cam was under that stream spinning.
Those enginetech lifters... holy sh*t oil is EVERYWHERE splashing all over a spinning cam. I mean is that a fix for needle bearing lubrication?
Then that goes back? Okay you saying you have no oil pressure? I am going to try to call engine tech maybe...
Btw those lifters are made in USA.
Hi guys. First post on the forum. I’m an old skool engine builder. When we had this problem on high lift roller cam SBC’s we put a .005 groove from the oil band on the lifter to the bottom of the lifter so it would flow a very small amount of oil to the rollers on the street. Problem solved. We use triangular needle files. My new to me 2012 2500 Hemi had a new cam and single lifter put in at 89k. Now I own it living a thousand miles away from the shop that did the work. Guess what I have? Yup a ticking lifter at 105k. Sooo if I’m going to do this then it’s coming all the way down and getting lifter grooves and a full freshen.
Bob
I think that would work. but I think if you put two small oil reliefs to feed the needle bearings(cam) would be a good "fix". Many guys play by drilling a hole on top and bottom.
I was thinking two reliefs would get oil out exactly at the area to feed the needle bearings. (then move to the cam). And put these up top.
36k bumper to bumper. drive train has a different warrantee though. 50 or 60k don't recall what it is but it was covered. Dont normally opt for the extended warrantee because I usually trade up every other year, so I don't run into this kinda problem,LOL.
Yeah - ask them to define "rare". Why would it be "rare" for a 6.4L HEMI, and not for a 5.7L HEMI when they share the same block and head? In fact, the cylinder heads are the exact same part numbers. Google it.
I don't believe them or trust them anymore. Their continued attempted evasions have built bad customer relations on a major failure point. I'm especially displeased as I traded my 07 Chevy 5.3L oil-pumper for the supposed superior 5.7L HEMI in 2012, then my current 2017 6.4L HEMI to get away from lifter / cam failures.
Being forcibly-retired early, I can't afford to trade-up every other year, nor can afford a Cummins. Not. Happy.
