Electronic Assisted Power Steering Failure
31K views 15 replies 7 participants last post by  Tred
#1 · (Edited)
At 35,500 mile the power steering started to act up. The steering wheel was very stiff for the 1st 15 degrees of a turn, then loosen up to normal, and then stiff again as you continued to turn the wheel. When you turned the wheel, it would not return. So as you went around a bend, you'd better be prepared to straighten the wheel... As it stated to happen it would come and go, but as it warmed up it would be normal. Until now as its acting up all the time now.
I 1st checked for a recall... there was an issue with a few steering racks, but my vin was not part of the recall.
Mileage continues to climb... now up to 36,500. Called the warranty dept., was told they needed an authorization work order from a dealer before they could get involved.
Got an appointment at the local dealer, took it in and was told sorry we over booked and you bring it in next week... mileage now up to almost 37,000... Took it back in today (now mileage over 37,200.) and asked if I could get a ride to my office as it's just down the street. The warranty manager offered... I mentioned we should take my truck so he could see 1st hand the issue... I explain to him it's there to have the steering looked at... he pulls out onto the road and was like HOLY CRAP what's wrong with the steering... I again explain I believe it's the Electronic Assisted Power Steering failing. He was shocked... I also threw in that I believe it's a safety hazard... that I can't allow anyone but me to drive the truck ... :i_rolleyes:
Just received a call from the dealer... yes it's the Electronic Assisted Power Steering Rack that needs replaced... was told even though you are over your warranty mileage, we're going to complete the repairs under the warranty... :smiley_thumbs_up:
I priced the parts from Dodge... minimum $1,500 plus labor, so at least $2,000.... to replace the steering rack.
Thanks God they honored the warranty or it could have gotten ugly...
#2 ·
Good to hear you got a resolution.
There have been a few of these reported here but not many. I'd say that there are more who have reported 200,000+ miles on their original rack than have reported failures
#3 ·
I really like the truck but have have little issues I’ve had to deal with... example front wheel bearings, went bad, not covered because of my lift kit. Back up camera was replaced under warranty but still fails from time to time. But most important the electronic assisted steering rack needs replaced. With a repair bill close to $2,300 I’m very happy the steering rack is being replaced under warranty.
#4 ·
Hi eprovenzano,
We are happy to hear that you are currently working with your dealer to have this steering concern resolved. If you are in need of additional assistance while your Ram is in service, please feel free to message us.
Darlene
Ram Social Care Specialist
#6 ·
I'm back to report that I have good news and bad news...
New steering rack installed, including alignment... :smileup: Bad news, its still acting up... not quite as bad, but still not right. :smiledown: Next they are going to replace the steering stem thinking a universal has seized. Almost, but yet so far... :doh:
At first they tried to blame the lift... I shut that BS down pretty quick.. I've put over 15k miles on it with the lift without issue. The lift keeps the steering is in the factory location, with the factory geometry. The steering rack is untouched with the lift. The replacement knuckles keep the tie-rods in the factory position. After I gave the Service Manager the facts, he agreed it's not the lift... the only thing left is the steering stem. :shy:
#7 ·
An appointment for Friday has been made to have the intermediate steering shaft replaced. I will also be discussing the tire alignment they did.. now the steering wheel is not straight, and the truck pulls to the right... yes I will make sure I'm satisfied before I sign off on the repairs...
#8 ·
Hi eprovenzano,
We are sorry to hear that you have some concerns with your Ram. If you are in need of additional assistance while your vehicle is in service on Friday, please feel free to send us a PM.
Darlene
#9 ·
Well I’m happy to report that the universal on the steering shaft was bad... the shaft has been replaced and it’s like new... the universal was shot... again they agreed the lift was not the issue... it’s been fixed under warranty, they centered the steering wheel and realigned the front end... all is good, thank you Dodge Ram for standing behind your products
#10 ·
Great news... the issue was the universal in the intermediate steering shaft. It was shot, lost of play that would cause it to bind up... They replaced the shaft and now the steering is like new... as it should be with a new steering rack and steering shaft... ?. They centered the steering wheel and relighted the front end. I want to thank Doddge Ram of Elm Grove for making the repairs... I’m a happy customer
#11 ·
Good to hear, thanks for following up with what the fix turned out to be
#13 ·
Hi ramcares (Darlene),
I've seen some of your comments regarding the EPS issue on a lot of these trucks and thought I would write to you directly. My son has a 2013 Ram with approximately 200k kms. In the past month his EPS light has come on intermittently and he lost power steering while driving. Each time it has happened, he has had to struggle with the wheel in order to avoid causing an accident. I have looked at the cost of replacing the EPS gear and it is prohibitively expensive, especially given the fact that this seems to be a known and common issue with these trucks. I realize that Dodge has not issued a recall for this year - only for the 2015 and 2016 - but as it appears to be the same issue, I am wondering if something can be done here. After all, it is a safety issue. Please let me know. Thank you
#16 ·
