:i_rolleyes:*sigh*:i_rolleyes:
I got in an argument with a Ford guy about this once- he kept going on about how its not a real Hemi. I asked him what is it then, a wedge head? A flat head? The smirk on his face and lack of response told me that he probably didn't know what the difference was.
The technically correct answer is that the gen 3 Hemis are a polyspherical head engine. The pistons are domed on top except for about the outer 1/4" or so; and the valves are at differing, yet still opposed angles, so the heads look like 2 hemispheres put together with quench bands cut into them:
The 2nd gen Hemi had an actual hemispherical chamber and much more pronounced dome on the pistons (and you should see some of the pistons that drag racers have experimented with:wow
The 426 Elephant was awesome in its day, and really still is, but the gen 3 Apache Hemi makes more power with only 392 cubes and is more efficient. Because of the era, the power was more accessible in the elephant due to the lack of nannies in vehicles at the time. The main reason for the polyspherical heads instead of true Hemi heads is that even with dual plugs, a truly hemispherical head would not meet modern emissions requirements.
Mopar actually offers a gen 3 426 Hemi crate engine available with a few different cams, that make 600/590, 515/490 565/550 HP/TQ respectively.
They also make a crate 572 Hemi that is a true gen 2 with a carb, and the option to add a 2nd carb. It makes 650/660 HP/TQ, and is a bit more of the traditionalist's option given the distributor and carb setup.
Both the gen 2s and gen 3s are somewhat legendary for their day. The gen 2s for being a legendary muscle car engine that has served as the basis for the overwhelming majority of top fuel drag car engines. The primary drawback in that application is the cost of valvetrain work.
The gen 3 has been even more popular if not as legendary, with the 5.7 alone seeing successful use in everything from sports sedans to SUVs to 1 ton trucks, and you'd be hard pressed to find a gas truck engine with a better track record of longevity and durability in hard use applications. The SRT versions (6.1, 6.2, and 6.4) have their own reputation for being reliable and powerful.
