201 - 220 of 330 Posts
mine never fogged up or got enough rain to impair the camera
the only time that the camera is worthless, is when the Sun is at just that height to blind the lens
hmmm. maybe i'll have to bring it in then. does sound like my lens needs to be changed
Id love to just see what is involved at the radio end for the harness at the head unit. I've pulled the radio out multiple times and even popped off the tailgate panel etc and found all those parts. Just the headunit is the mystery for me. Hoping I can get a picture or something of what JeepGuy has done.
Wow, 21 pages and no easy install of a back-up cam. Rear visibility sucks from my 13 Ram 4X4 quad. Previous truck was 85 F150 2wd and had no probs. Get up in the AM to go to work and am now paranoid backing out of driveway. Shoulder check & mirror check then repeat. This $50 factory install should be mandatory. Have U Connect 5.0 (like my Mustang LOL). Read somewhere on the net that back-up cams will be mandatory soon. Got it off the net so it must be true LOL. So easy for a child to be in the blind spot.
I ordered one last night along with the OEM brake controller so I only have to pay the dealer once to program. I will advise how the install goes. For the price, you can' t beat it.
I don't know if anyone else has seen the new Mopar brochure on Accessories for the 2013 Ram but they did add a back up camera with the picture in the 8.4 display. On Mopar's site they also added a backup camera but it says its for the RA1 only since its a rear view mirror replacement screen. I just got my truck about 3 weeks ago and have been looking to add one and checking mopar often and the camera wasn't there till maybe last week.
I actually ended up having to go to the dealership this week for a safty recall and talked to the sales rep I bought the truck from and he said they can now add a camera that either displays in the 8.4 screen or in the rearview mirror. I don't know if I take his word on it after seeing all the head ache its been for others, but it could be true. I do remember asking though when I got the truck about it and being told no.
It should be done by next weekend. The brake controller may be here today. If I get it installed, I will have the dealer flash it Friday and activate the camera. Then I can test it next weekend after installation. They recommend activating prior to installation of the camera so you can test it.
I got the kit. It looks great. Looks oem. I just got my running board brackets and want to do those first.
I just got my 2013. With the nearly $4k rebate, there were only 3 express crews in my state. Only one with chrome 20's, mineral gray. I had to have the visual display package, and there was only one, with no camera. So for $199 and 2 hours of my labor, I got the backup camera now. Besides I love working on my cars. So anything I can do myself, I love to do.
I could have ordered a '14, no rebate and waited a few months, but I wanted it now.
There was another in another state that had the camera, but no hitch. It was not worth having a dealer 250 miles away so no free rental for service.
So anyway, thats the long story. Sticker was $39000 even, and I paid $31000. A 14 would have been 35k or more.
2013 Uconnect 5.0 (and 8) $199 backup camera installation
Well I did it. Started at 7:30 Am and was done by 10:30. The only reason it took so long was trying to feed it out of the cab. Dodge actually made it real easy, but you need some silicone spray to pull it through. Below is the easiest method and takes minutes.
Anyway, all the photos are here: http://sdrv.ms/17cW5Eb
Buy the Echo $199 (free shipping) kit from Parrot Sales (ebay or their site). I got it in 3 days.
It comes with a new latch with camera, wiring harnesses and good instructions.
All the extra you will need is some heat shrink (not a necessity but I live in the salt belt and it made the install much easier. $3.99 at radio shack) and some tie wraps. Also two quick wire connectors like these
http://www.autozone.com/autozone/ac...nnection-quick-splice-terminal/_/N-25oe?itemIdentifier=510814&_requestid=561845
I started at the tailgate. Remove the cover, remove the plug on the power latch (hint slide it to the drivers side and it comes off the pin holding it to the tailgate).
Remove the two rods by rotating the clip and pulling out towards you. Remove the two nuts holding the latch in place. I think it was an 8mm socket. May have been a 9 mm. The latch comes right out.
Remove the two 7mm or 9mm bolts holding the key cylinder on the latch and transfer it to the new one with camera.
Installation is the reverse. Run the new camera wire to follow the existing harness. As it comes out of the bottom of the tailgate, there is a hole to the underside. I went through that. I added some heat shrink to the armored cable so it would not rub on the paint and wear through. Bring the wire toward the drivers side and clip to the tailgate harness. Leave it hanging down at the corner where all the harnesses come together underneath.
You can put the tailgate back together. You are done at that end.
Now it took me a while to figure out how to run the long harness, but my work will make it much easier for you. Open the hood. Under the main body wiring harness in the drivers firewall corner, there is a future connector right under the big one. It's like a rubber nipple. Cut off about 3/8" of this connector so it is open.
Here is where I spent 1 hour or more. I tried a plumbing snake, screwdrivers, everything, I could not shove the rear connector through the hole from inside the car. Finally, I did it. First use silicone spray. Second, See my pictures, I heat shrinked over the connector and shrinked a large long tie wrap at the connector end (the latch of the tie wrap at the connector end). Then I heat shrinked a smaller piece on the over the tie wrap thin end to lock it in. (I would add another piece too for overall strength. Coat the heat shrink with lots of silicone spray. Push it through the hole in the grommet from inside the car. The tie wrap end will come out under the hood, below the harness. I just pulled and it came right through (actually my heat shrink shrink broke when the plug was at the open end of the rummer grommet). I grabbed it with needle nose pliers and it pulled right out. Next add silicone to the armor of the cable and pull the wire through. About 18' of wire. I left 3-4' in the car. I think you really need about 30-36".
Next push the rear connector down where the body harness goes down inside the wheel well and it comes out behind the front tire inner fender. Pull the wire out here and leave a 3" radius bend from the grommet turning down where the harness goes.
Now easy work ahead. Run the armored harness along the factory harness. Use tie wraps every 10" or so. This took 15 minutes all the way to the rear. I added heat shrink to the ends of the armor to the connectors for a watertight seal. I then made the connection at the rear plug and wrapped it with tape to be sure it water , snow and salt tight.
Remove the center dash. Simple remove the two screws under the top coin tray (they are a torx) and they pull at the top and sides. The dash comes right off. I laid it flat between the dash ashtray and the console. I connected the red and black power leads with the quick connector to the 12" accessory outlet wires on the lower left, under the 4WD selector. This was a royal pain. The tape the factory uses would not budge. Normally I would solder and heat shrink, but connectors made it so easy. I wrapped these with tape and reconnected the accessory outlet. The tab is on the left and gave me some trouble to disconnect.
Finally remove the 4 radio screws. Pull it straight out. Undo the connector on the left. Insert the yellow prong in hole 31 and the black in 32. The upper right of the connector (looking at the wires).
Plug in the radio, connect the RCA connector to the yellow matching end.
I then turned on the car, put in in reverse and the camera worked! The only thing it does not do is the grid lines do not turn with the wheel. Also, I have a low short ball mount. I can only see the last 1/2" of the ball on the bottom of the screen. But it is enough to connect a trailer.
The bottom of the screen is about 10" from the Bumper or so in real life.
That is it. It was easy and rewarding. The dealer flashed it for free and I had the materials. About $205 fully installed. And about 2 hours labor.
Some Photos are below. All are posted here. http://sdrv.ms/17cW5Eb. By the way,, the pictures are all named what they are. I did not upload in order.
Enjoy!
Way to go Nburd success ! I have to watch my posts,posted jeepguy and got deleted by moderator,i need 75 posts to buy sell . I was inquiring about harness and ended getting deleted. Oh well. I hope a kit will come out that will have everything with factory camera and the lines that turn. Don
