No-start and "service shifter" issue
I just had a two-part episode with my 2013 Ram 1500 3.6L 4WD. the first sign of problem was about a week ago when the vehicle failed to crank when I turned the key. I couldn't get the shifter out of park either. I tried to get it started multiple times, and tried both of my keys... no luck. I called roadside assistance and as I waited for them to arrive I learned how to pop the trans out of park using the manual override just to make sure the guy wouldn't drag my truck and tear it up.
Of course it started as soon is the tow truck dropped it at the dealership... my luck. I had never tried to start the truck after I popped it out of park, but I'm guessing that it would have started for me if I had thought to try it.
Long story short, they checked the truck, cleared the codes and performed flash programming updates and I took the vehicle back. The next day the check engine light came on and the "service shiftier" message displayed on the dash. I reported this to the dealer and they ordered me a shiftier module.
Over the next few days the message came up numerous times, usually at lower speeds as the trans is upshifting or downshifting. Today they installed the new module (rotary knob/shifter assembly). So far, so good... I've got my fingers crossed. Still not too sure what caused the initial no-start condition.
I know this post is a few years old, but i wanted to reply to it. I tried to start my 2014 RAM via the remote start, but it did not start. I sat in the truck, turned the key to the start position, and EVERYTHING went dead. ALL lights went off. I released it to return to "on" position, and the system "rebooted", and a message came up that said "service shiftier". This sounded like a bad / dead battery, but there had been no warning signs (slow cranking, etc). I disconnected the 2 cables, waited, then touched them together to completely reset the electronics, and tried again. Same issue, same warning message. Disconnected AGAIN, put a charger on the battery (showed 70% charge), waited until 100% charge, connected, tried again. Again, nothing, no crank, just some clicks, and a completely dead electronics. After it came back on, the message "service shiftier" came up again. Called 2 dealers, they BOTH stated that it would be 2-3 weeks before they could take a look at it, and I would have to rent a car at (about) 35 dollars a day. Called a few auto repair, they stated they could get it in right away, and that they could not give me an approximate price, BUT, it was 135 dollars for a systems check. I was stuck, so I called my roadside service for a tow truck to get my RAM out of my garage (while stuck in park) to get towed to the closest repair center. Called a few repair centers, told them the issue, wanted to make sure a "non dealer" service center could handle this. They all said yes, and that I had to get the truck to them. Tow truck shows up, driver asks me the issue. I explain the no cranking, the shiftier service message, and he said "Sounds like a dead battery" Yeah, no sh*t Sherlock...explained to him the procedure I went through, and that I had fully charged the battery with a battery charger, but no improvement. Well, he said he would try to jump it anyway. At first I thought this was a ploy so he could charge my insurance company more, but then I said "Great, prove me wrong" Hooks up the jumper cables, and BOOM! my truck started right up. To say I was flabbergasted is an understatement. He stated that this happens all the time, especially in cold weather. Since my truck was 5 years old, and had the original battery, he said he was not surprised. What threw me was the error message "service shiftier". It seems that if the electronics read that the engine will not start, it will not allow the shiftier to release from park, hence the message. The other item that threw me was that since this was such a common issue, why did not all the centers I call suggest to jump start the vehicle? When I called the dealers, I was connected with a scheduler, (so their response is understandable), BUT, when I called the service centers, I spoke with the managers, whom I would assume are mechanics. I posed this same question to the tow truck driver, and he simply stated "They wanted your money"
