I have a 2014 Ram 1500 4x4 Big Horn. This afternoon I get into the truck and cant turn the wheel. Have a message to "Service Power Steering" and indicator on. Any suggestions folks. I only have 20k miles
OK, so I will try to shed some light on this issue. If you look at other forums you will see this is a continuing issue with the Ram (1500 and 2500 at least). I started having this warning and loss of power steering a couple of months ago 2014 Ram 1500). It is very random and would normally do this upon start up. I would let it sit a minute and restart and it would be cleared and work fine. I spoke with a service manager and was told they could not do anything unless the warning light was on as the code thrown is not saved. One day I was driving and the code was thrown and no power steering. Drove for 17 miles straight to a dealership. They pulled the code but did not have a tech available to look at it. When they started it up the next day, no warning. They had my truck for 5 weeks and could not get it to duplicate. The day before I went to pick it up the dealer told me they just got a 2019 Ram 1500 in with the same problem. Again could not duplicate after restarting the truck. The day after I picked up my truck, the code was thrown and no power steering, unfortunately no dealers open on Sundays. The code is frustrating the dealers as it does not tell them where or what the problem is. They have to trace it from the main CPU through the sensors to the rack. The failure could be anywhere. The cost to replace the entire rack is about $2300. This is a very frustrating issue that Dodge knows about, in fact there was a recall on the 2015 Rams but no others. This is a very unsafe issue as well. If you lose power steering on a winding road (I live in NC) you may be thrown off the road, same for if it's out and then corrects itself. There are also problems on the Chevy and Fords as they now have the same steering set up. I looked at a new Tundra as they have the old school pump/hose steering, but their top of the line is still a step down to the Ram Laramie. Sigh.
[/QUO
just curious were you able to get this matter resolved? I have a 2014 ram 1500 and I’m starting to have the same issues. It only happens to me when I first start it up and if it’s cold outside. I drive for about 3 minutes and then i restart the truck and the steering is back to normal. Starting to get very frustrating.OK, so I will try to shed some light on this issue. If you look at other forums you will see this is a continuing issue with the Ram (1500 and 2500 at least). I started having this warning and loss of power steering a couple of months ago 2014 Ram 1500). It is very random and would normally do this upon start up. I would let it sit a minute and restart and it would be cleared and work fine. I spoke with a service manager and was told they could not do anything unless the warning light was on as the code thrown is not saved. One day I was driving and the code was thrown and no power steering. Drove for 17 miles straight to a dealership. They pulled the code but did not have a tech available to look at it. When they started it up the next day, no warning. They had my truck for 5 weeks and could not get it to duplicate. The day before I went to pick it up the dealer told me they just got a 2019 Ram 1500 in with the same problem. Again could not duplicate after restarting the truck. The day after I picked up my truck, the code was thrown and no power steering, unfortunately no dealers open on Sundays. The code is frustrating the dealers as it does not tell them where or what the problem is. They have to trace it from the main CPU through the sensors to the rack. The failure could be anywhere. The cost to replace the entire rack is about $2300. This is a very frustrating issue that Dodge knows about, in fact there was a recall on the 2015 Rams but no others. This is a very unsafe issue as well. If you lose power steering on a winding road (I live in NC) you may be thrown off the road, same for if it's out and then corrects itself. There are also problems on the Chevy and Fords as they now have the same steering set up. I looked at a new Tundra as they have the old school pump/hose steering, but their top of the line is still a step down to the Ram Laramie. Sigh.
ok I took the cover off and looked in side at the belt but the belt was good still 12 volts at plug in on the rack & pinion module not sure what to do nextNo sir eBay but here’s your belt in the link Dodge Ram 1500 2013-2016 Electronic Power Steering Drive Belt
part number 28274888No sir eBay but here’s your belt in the link Dodge Ram 1500 2013-2016 Electronic Power Steering Drive Belt
