21 - 40 of 66 Posts
I swapped out my Ram's GY SRA's for a set of BFG KO2's. My sway is gone at 150km/h (92mph).
Just another update. I put in the new springs and the problem still persists. The springs were very easy to put in and they work well. At the moment they lifted the rear of my truck about an inch. I towed my trailer and the rear hardly came down. Had about 1000 lbs of wood in it today and didn't even notice it. The ride is practically the same without a load. Just a tad rougher but not much. Don't know what I am going to do next. Any suggestions???
Did you front and rear springs or is all of this work on the rear only? Other thing to check would be sway bar end links. If there's looseness in either end those bushings, might be contributing? Do you have a tonneau cover, or cap, maybe its some wind buffeting that's exacerbating the problem?
Discussion starter · #23 ·
Yes everything has been done in the rear of the truck. It gets more pronounced with more weight in the back. That is why I was solely working in the back. I do have A bed cover. I might think about the tires next but that will be a couple of years down the road. It also does not do it while I am towing my camper either.
How about air bags. I just got my Air Lift 5000 bags but have to install them yet. I'm told it helps with the sway.
I bet dollars to donuts it's your tires. Mine did the same thing.
Try grabbing onto yoyr bedside and shaking the truck side to side. It was crazy how much the wheel moved back and forth as the tire sidewall moved. I added pressure to the rear tires and it went away.
Try anew or at least new bushing on the panhard bar. If the truck has lifted it will need to be lengthened so the truck doesn’t crab. If that or the control arms are loose and or worn out bushings that will be your sway.
I have a 2017 ram 1500. I have the same problem. Also some times feels like my rear end sways when I suddely let off the throttle. I got air bags in the back, new shocks all the way around, new springs in the rear, and new away bar links and bushings all around. Everything seems right and as it should be.
I first started noticing these problems at about 80k miles I now have little over 100k.
I am starting to loose hope in fixing the problem.
I tow a 6x12 enclosed trailer quite often. And it has gotten to the point where it is actually almost scary to pull a trailer cause the trailer magnifies the issues.
update, it WAS the rear control arm bushings. both upper and lower control arms bushings in the rear passenger were bad. I replaced all 4 just cause. hard to get them from auto parts stores though so I ordered strait from dodge dealer.
thank you for all the help, this has been driving me crazy for months now.
I think the problem discussed in this problem is very common among truck drivers) you know, when you spend equal time with your wife and your mechanic, you have a lot of experience to share :D but I was always afraid to comment on forums because you never know the whole picture and can give a wrong advise. I have read somewhere about a guy who wanted to clean the car seats and someone advised him some solution. In result, he had to change the sets. That`s why I use forums more to read and then I always double check on reliable resources) if you are really interested, you will find a lot of platforms like Difference Between Highway and Freeway (With Table) – Ask Any Difference with great information written by specialists.
I haven't noticed anything that seems loose or worn out. It only happens in the rear of the truck.(well that is where it seems to be) It is like a rocking back and forth. It doesn't happen all the time which confuses me. I was wondering if anyone else has had the same issue.
I just had the same issue and posted about it. I was hauling furniture from South Carolina and the truck Rocked back and forth, when I hit a bump it would become more violent and the cruise control would shift off and cause the truck to decelerate rapidly. The first time it happened I thought the trans was going out.
According to the tire pressure sensors everything was at 40 except for one which was at 39. We have 70,000 miles on the truck never experienced anything like this before.
21 - 40 of 66 Posts
