Installed the Tuftruck 1223v springs today.
A few thoughts.
1 Why the hell didn't Ram install a spring like this at the factory.
2. See #1
3. I installed the springs with a Daystar 1" spacer, after the install of my 1.5 leveling kit the truck was level but visually it looked to me that it had a bit of the bro lean. The new springs with the 1" spacer is perfect.
4. I always felt like I was driving a 52 Desoto. To much body lean when turning and too much wallowing if you went thru a small dip. These springs helped a ton. Not near the lean and no wallowing. A set of good shocks would make it even better.
5. Ride is 1000% better, a bit stiffer unloaded but that was what I was hoping for. it now feels like a truck but still softer than a leaf spring truck. The ride is perfect.
6. Towing- I didn't tow my rv trailer but I hooked it up and put the 700# tongue weight on the truck. Before the springs the ass end would drop a good 3 + " today it only dropped 1"-1.5". With the weight distribution hitch hooked up with very little chain tension it was perfectly level.
Hope this info will help anybody thinking of doing the spring upgrade.
A few thoughts.
2. See #1
